KNX - DALI interface
    Hi. Sorry if this has been asked about before, but my german is really bad and I could not find any good answers.
    What is currently the best knx - dali interface?
    I'm building a new house and will have about 120-150 dali devices (yes, each led spot will have it's own dali led driver). So this means I need three separate dali circuits.
    I want to have both individual control of the lights as well as scenes and group control. Which interface would be the easiest and best to manage this? I have been looking at the Siemens 5WG1141-1AB21 and MDT SCN-DALI64.02 and would like other recommondations also.
    It's ok if you write your answer in german, I'll just use Google translate...
    Zuletzt geändert von McKajVah; 06.11.2015, 18:55.
    if you really want to plan with 150(+) DALI devices you might not need three DALI Gateways...
    If you use the 5WG1141-1AB21 in combination with a 5WG1141-1AB03 you are able to control 192 devices
    TWIN PLUS (2 x 64) and PLUS (1 x 64)
    The one thing that made me choose the Siemens 5WG1141-1AB03 [ the PLUS, not the 1AB02 !! ] (I have way viewer devices) is that you are able to specify up to 6 Standby circuits, which will enable you to switch off power to some EVGs while still having DALI-BUS enabled.
    This way I can switch off hallway, kitchen, living room, basement EVGs separately when no one is in the area.
    150 EVGs will generate one hell of standby power consumption
    Hope this helps :-)
    David
    Zuletzt geändert von Masterdrive; 06.11.2015, 18:59.
      Zitat von McKajVah Beitrag anzeigen
      yes, each led spot will have it's own dali led driver. So this means I need three separate dali circuits.
      Why should every spot has his own driver? There are multi-channel driver available - so you can reduce the amount of drivers but each channel could be separately controlled. Check this option.
      GLT
        Thanks for the answers.
        I'm installing about 110-120 led spots, outdoor lights and extra "effect lighting" total of around 150 dali devices... I already have the DALI-drivers (I got them really cheap) but I also have the normal 230V drivers for each spot. The reason for going with Dali drivers is because of individual control of the lights and also perfect 0-100% dimming.
        The standby power of all the drivers should not be more than 20-30W, not to much and the power is not wasted as the house will need some heat...
        Will I have problems programming and controlling this many Dali devices (not recommended?) or should there be no problem?
        David
        I could not find any info on this, or is it the "emergency" function of the gateway?
          "emergency"... no
          this is a feature
          Zitat von Application documentation Chapter 3.3
          Stand-by
          This function makes it possible to define up to 6/12 areas,
          for which the ECG power supply is shut off by a separate
          load switch when all of the ECGs in this area have a
          brightness value of zero (0). This serves to reduce the
          quiescent power consumption of the ECGs.
          you may find it in the application documentation
          https://www.hqs.sbt.siemens.com/cps_...-03_APB_en.pdf
          David
            "emergency"... no
            this is a feature
            David
            Thanks, found the information about standby now.
            This is genius!!
