ETS Inside und ETS 5.5
  • valour
    Hello uwe1 ,
    Could you please inform me about the Android version your device runs?
    Thank you in advance,
    Best regards,
    Vassilios Lourdas
    System & Tool Engineer
    KNX Association
  • valour
    Hello uwe1,
    We have to check this issue out. Thank you for pointing out!
    Best regards,
    Vassilios Lourdas
    KNX Association
  • uwe1
    The resolution of my smartphone (Google Nexus 5) is 1920x1080 ... so big enough.
    Below the red line it's not clickable.
    Above the red line it's not scrollable.
    So I can not click on the "Verbinden"-Button.
    But nevertheless ... I think a smartphone is to small for "working" with the inside.
  • valour
    Zitat von Videonisse Beitrag anzeigen
    isn't type of device the problem? Or are phones supported?
    iPhones are not supported by definition because of the minimum screen resolution. Only the iPad family products are supported that run at least iOS 9. On the Android platform we cannot exclude device families, therefore it can be installed on any Android device running Android version > 4.0. But, if the requirement for the minimum resolution is not met, then one will face the layout problem. We will however, have to work on a layout for devices with smaller screen resolutions as well.
    Best regards,
    Vassilios Lourdas
    KNX Association
  • Videonisse
    Zitat von uwe1 Beitrag anzeigen
    Thanks valour!
    One feedback for the Android Client App on a Smartphone: It does NOT scroll.
  • valour
    uwe1 Actually, it can run properly on all Android devices having a minimum resolution 1024x600 px. Unless you mean something else. Could you please send me a screenshot?
    Best regards,
    Vassilios Lourdas
    KNX Association
  • uwe1
    Thanks valour!
    Zuletzt geändert von uwe1; 16.02.2017, 20:18.
  • valour
    Hello uwe1 ,
    Actually it is in "Publishing" status by Microsoft, it should appear within the next hours.
    Best regards,
    Vassilios Lourdas
    KNX Association
  • uwe1
    valour : How about the ETS Inside client App for Windows?
    The Windows Store says: ETS Inside ist zurzeit nicht verfügbar.
  • Manuel83
    OK thanks, now i have found the app.
  • valour
    Zitat von Manuel83 Beitrag anzeigen
    ETS Inside App im Apple Store? Kann ich nichts finden....
    Hello Manuel83 , the App is visible only if you are browsing with an iPad. If you are with an iPhone, it's not. You can find the iTunes link here.
    The ETS Inside client can run in 3 different operating systems, for which, the respective client has to be downloaded from the respective...
  • Manuel83
  • coliflower
    Thanks !
  • valour
    Zitat von coliflower Beitrag anzeigen
    valour, what Apple-devices can use the ETS-Inside-App ?
    Hello coliflower you can find this information here. But, a quick answer is iPad family only.
  • coliflower
