Hello uwe1 ,
Could you please inform me about the Android version your device runs?
Thank you in advance,
Best regards,
Vassilios Lourdas
System & Tool Engineer
KNX Association
ETS Inside und ETS 5.5
The resolution of my smartphone (Google Nexus 5) is 1920x1080 ... so big enough.
Below the red line it's not clickable.
Above the red line it's not scrollable.
So I can not click on the "Verbinden"-Button.
But nevertheless ... I think a smartphone is to small for "working" with the inside.
iPhones are not supported by definition because of the minimum screen resolution. Only the iPad family products are supported that run at least iOS 9. On the Android platform we cannot exclude device families, therefore it can be installed on any Android device running Android version > 4.0. But, if the requirement for the minimum resolution is not met, then one will face the layout problem. We will however, have to work on a layout for devices with smaller screen resolutions as well.Zitat von Videonisse Beitrag anzeigenisn't type of device the problem? Or are phones supported?
Best regards,
Vassilios Lourdas
KNX Association
isn't type of device the problem? Or are phones supported?Zitat von uwe1 Beitrag anzeigenThanks valour!
One feedback for the Android Client App on a Smartphone: It does NOT scroll.
Hello Manuel83 , the App is visible only if you are browsing with an iPad. If you are with an iPhone, it's not. You can find the iTunes link here.Zitat von Manuel83 Beitrag anzeigenETS Inside App im Apple Store? Kann ich nichts finden....
Hello coliflower you can find this information here. But, a quick answer is iPad family only.Zitat von coliflower Beitrag anzeigenvalour, what Apple-devices can use the ETS-Inside-App ?
