Zitat von pbuechel
Beitrag anzeigen
Topologieänderung für RF nötig ??
Zitat von Gaston Beitrag anzeigen...I was always wondering how IEC and espceially ISO could accept this specification wherfe ambiguity between terms are given (same Name "Line" as physical or logical entity). I was used to especially the ISO to be very strict on such ambiguities.
Zitat von Gaston Beitrag anzeigenThe specifications specify in point 1.3.2 in the TP part, that "Bridges are used to combine physical Segments to a Line in order to achieve longer distances and to allow up to 255 devices (Figure 25) on a Line with TP1-64 devices."
Zitat von Gaston Beitrag anzeigenThe drawing joined to this shows a bnride in the backbone line. Also all subsequent figures show bridges in all types of lines. There is however abiguity again between backbone and main lines in figure 26. The best ist that lines markes as "Lines" actually are "Main Lines".
Zitat von Gaston Beitrag anzeigenNow the argument one could throw in to say that the drawings are wrong because point 1.3.2 speaks about logical lines (while it doies not explicitely state it does). Don't know how the ISO works topday, but this would have been a reason for the ISO to throw over and invalidate the whole specification in the past as it clearly shows the ambiguity.
Zitat von Gaston Beitrag anzeigenHowever here comes the glossary to help which specifies the bridge/repeater in the physical and not the logical line. So it is well the only place without ambiguity and it clearly includes the brige/repeater. And yes the main line is a physical line....
But this is also some bad will interpretation: Bridges and Repeaters are only mentioned in the definition of the Line, not in the definition of the Main Line or Backbone Line.
Zitat von Gaston Beitrag anzeigen...I can't see any reason to forbid the presence of bridges/repeaters in main/area line provided the specification that states "Not more than 6 Couplers (i.e. Bridges or Routers) shall be between any of two devices".
