Jung LS 5094 TSM - 2 channel operation
    Hello,
    I'm using Jung LS 5094 TSM in my project and just found out that the 2-channel operation is pretty useless compared to other brands. I'm missing the 4-bit dimming operation i 2-channel mode.
    In my experience this i common feature when talking 2-channel operation. especially in a modern and top-of-the-line push button.
    I want to recall scenes with short press, and dim with long press without storage. I know it's possible to solve with some logic functions, but I like to keep functions simple and not use more external logic than needed =/.
    Anyone know if there's FW/database update comming soon for the LS50? Perhaps this function will be implemented in this otherwise very powerful pushbutton!
    Thanks!
    Hello
    no!
    you Can use The two-Button funktion
    short press Switch 1bit
    long press dimm 4 bit
    and with two Buttons (left and right at the same time) call a Szene 1byte
    the funktions are permantly set in swich, dimm, shutter ...
    bye
    Henning
      Thanks, that's what I found out aswell that theres a "Full Surface" option.. But it seems like I can't do what I intend to do with 2 scenes and dimming..
      I might have to solve it with Logic operation. Sending a 1 bit that translates to a 1 byte value. But I really don't want the Project to depend on the logic module, because if it gets broken the whole house will go down, which is pretty bad.
      I really can't understand why Jung doesn't have the 4-bit option in 2 channel operation, it's such a basic feature.
        It looks like I have ran into same issue.
        I use Jung 419x TSM switches and MDT dimmers.
        What would be the easiest way to get scenes and dimming on same button?
