RGB help (dutch?)
    DALI RGB help (dutch?)
    Hello,
    This is my first topic on this forum and i am from Holland so please forgive me if this question has already been asked on this forum. I am controlling my Aquarium (don't laugh) with DALI. I have 6x 80w T5 lamps on my tank. Now, my aquarium is controlled by a computer. Whenever there is something wrong with my tank, i would like to show this with leds. Preferably RGB leds and preferably controlled by DALI since i allready have this.
    To be honest, i am stupid with technical stuff, this means i don't know how to convert watts to amperage etc. so i don't know what to take;
    I am sure i need a DALI->PWM controller, and i thought of the K6-C003 RGB 8-24V, DALI) Controller. My tank is 1 meter 80cm wide, and 70cm in depth. If i want to make a RGB strip around my tank, this means i need to 'control' 3.2 meters with leds.
    I have seen a LED strip which is 26cm wide, uses 3W (per strip)
    12V +/- 0,5V (1 x 240mA (+)) (3 x 80mA (3 x -)).
    I would need 12 strips. But i don't know if:
    a) i can even control this using the K6-C003 controller
    b) if it supplies enough power
    c) if i need a driver or amplifier
    I've seen this in another topic, but i don't know if i need it...
    1 x K6-550-075-00 (Schutzart IP66, 12V=, 100W)
    1 x K6-C004 (RGB-Verstärker 12/24V) 6A
    Please help me and sorry for not asking in German.
    Easier with one of this
    LED-Shop - LED-Leisten: 300cm flexibler RGB LED-Strip - 108 x RGB Fullcolor LEDs Streifen 24V - 3Meter
    and one of this:
    http://www.tridonic.co.at/kms/media/...025_k211_d.pdf
    about 180 € in total.
    P.S. Welcome!
      Has one K211 enough power to control the suggested 3 meter RGB stripe?
      It has 3x8=24W and the stripe has about 26W.
      --Marcus
        Engineering tolerances
          Danke fur Ihr beitrage!
            Habe ich mir schon gedacht, dass das so noch geht
            Wie sieht es aus, wenn ich 9 Meter benötige?
            Drei Stripes mit drei K211 gibt bestimmt nicht das 100% identige Verhalten bei allen 3 Stripes.
            Könnte man es mit einem K211 und 2 Boostern (C004) jeweils am Ende des 1. und 2. Stripes realisieren?
            --Marcus
              RGB help (dutch?)
              Ja - kann man braucht dann eben ausreichenden trafo.
