Hallo Jürgen,
fixe ich heute.
Bis bald
Marcus
fixe ich heute.
Bis bald
Marcus
.logInfo
background: blue
calldiomus.core update callidomus.gui build callidomus.core restart
2016-07-22 13:16:37 DEBUG Main Visu: admin (192.168.102.32:49852) sent '{"cmd":"admin","admin":"getNodeAttr","path":"log2"}'
2016-07-22 13:16:51 DEBUG Main Visu: admin (192.168.102.32:49852) sent '{"cmd":"admin","admin":"getNodeAttr","path":"log2"}'
2016-07-22 13:16:53 DEBUG Main Visu: admin (192.168.102.32:49852) sent '{"cmd":"admin","admin":"modifyNode","path":"log2","attr":{"plugin":"Log","active":"1","name":"loglog2","type":"plugin"}}'
2016-07-22 13:16:53 ERROR Main 'NoneType' object does not support item assignment
File "/mfs/core/lib/websocket.py", line 364, in json_parse
self.admin(data['admin'], data)
File "/mfs/core/lib/websocket.py", line 422, in admin
reply = self._core.config.modify_node(data['path'], data['attr'])
File "/mfs/core/lib/config.py", line 453, in modify_node
obj['_name'] = attr['name']
TypeError: 'NoneType' object does not support item assignment
2016-07-22 13:17:00 DEBUG location.time Triggering location.time-code - by: Scheduler source: None dest: None value: {'value': '1', 'caller': 'Scheduler', 's
2016-07-22 13:17:00 DEBUG location.time-code Item location.time = 2016-07-22 13:17:00.212830+02:00 via Scheduler None None
2016-07-22 13:17:00 WARNING _kaco_wr Kaco WR: could not fetch csv: Problem fetching http://192.168.102.33/realtime.csv: timed out
