Hello experts.
I am new to KNX. These days I plan installation (on my own) for my new house and I don't understand clearly the function of binary inputs. I would like to monitor some devices through connection to binary inputs (closed windows, doors, heat pump compressor, ventilation etc.). Do I understand it clearly I can detect the status of inputs only on the change, not "ask" them to send status?
I would use the HS to do some logical operations on this inputs but I aware of one possible critical point. What about HS server freeze/restart and actual status of these inputs? When the input changed its position before HS restart it has sent telegram. Then HS is restarted and I don't know on HS the input status, because no change happen (after restart, because telegram has been sent already). So my logic operation could be evaluated by mistake.
I think this is common problem so can anybody tell me how to solve this? I think it can be avoided by cyclical sending of input status telegrams but what about bus load in case I have 32 inputs?
Thank you.
Thank you.
