Problem Gira 2167 00 - IP Router
    Hello,
    I have a Gira IP-Router, which I have some problems with. It is HW 04, and the current firmware is 2.0.134.
    The first problem is that I can't program the router through ETS using a USB interface, the physical adress gets programmed, but not the rest, I get an error message saying "Failed to write to one memory block"
    I have tested to do a factory reset of the router, by holding down the programming button when powering up the router, this does not help.
    So I went to Gira.de and downloaded the latest firmware, 3.1 and tried to update with GPA, but instantly I get an error, but when I open the details about the message, all I get is "https://IP-adress: portnumber/XMLRPC" no further explanation what went wrong. So I downloaded the "workaround" since there seem to be a communication problem with windows, but this did not help, still the same with both ETS programming and also the GPA firmware update.
    I'm using a normal RJ45 patch cable, not cross-over when trying to update the firmware, the router is connected straight to the PC, no switch or anything else.
    I'm out of clues, have anyone experienced the same issue?
    I have to admit that I f*cked up.
    I misunderstood activate/deactivate when using the GPA workaround, so when I finally used "deactivate TLS" this instead of activate I managed to update the firmware to 3.1. After that I was able to program the router through ETS with latest database without any issues and now it runs like a charm!
      HI
      I have the same problem here with HW04.
      I don't understood how to deactivare TLS.
      Were can i found that?
      MAny thanks
        Ferry,
        This page on the Gira website has the information you need. Download the zip file, which also contains the detailed instructions.
        http://www.gira.com/en/service/downl...d.html?id=2836
        Bram
