Nach dem GUI-Rebuild is alles weg
Kein Items mehr, keine Visualisierung.... etc.
Bildschirmfoto vom 2016-10-14 16:18:57.png
callidomus.core update callidomus.core restart callidomus.gui build callidomus.visu build
callidomus.support onestart
2016-10-14 20:50:58 DEBUG Main Item morgen: no type specified.
2016-10-14 20:50:58 DEBUG Main Item settings: no type specified.
2016-10-14 20:50:58 DEBUG Main Item system.connections = 14.0 via SQLite None None
2016-10-14 20:50:58 DEBUG Main Item system.data = 0.0 via SQLite None None
2016-10-14 20:50:58 DEBUG Main Item system.files = 130.0 via SQLite None None
2016-10-14 20:50:58 DEBUG Main Item system.load = 0.2 via SQLite None None
2016-10-14 20:50:59 DEBUG Main Item system.memory = 33.0 via SQLite None None
2016-10-14 20:50:59 DEBUG Main Item system.mfs = 6.0 via SQLite None None
2016-10-14 20:50:59 DEBUG Main Item system: no type specified.
2016-10-14 20:50:59 ERROR Main Unhandled exception: local variable '_trigger' referenced before assignment
<class 'UnboundLocalError'>
File "/mfs/core/bin/cd_core.py", line 663, in <module>
cd.start()
File "/mfs/core/bin/cd_core.py", line 261, in start
item._init_prerun()
File "/mfs/core/lib/item.py", line 518, in _init_prerun
_items.extend(_trigger)
2016-10-14 20:51:00 WARNING location.time Item location.time: value 1 does not match type dt. Via Scheduler None
2016-10-14 20:51:00 DEBUG Scheduler location.time next time: 2016-10-14 20:52:00+02:00
2016-10-14 20:51:52 INFO _knx_heartbeat KNX: trying to connect
2016-10-14 20:51:52 DEBUG _knx_heartbeat KNX: sending connect request
2016-10-14 20:52:00 WARNING location.time Item location.time: value 1 does not match type dt. Via Scheduler None
2016-10-14 20:52:00 DEBUG Scheduler location.time next time: 2016-10-14 20:53:00+02:00
2016-10-14 20:52:52 INFO _knx_heartbeat KNX: trying to connect
2016-10-14 20:52:52 DEBUG _knx_heartbeat KNX: sending connect request
2016-10-14 20:53:00 WARNING location.time Item location.time: value 1 does not match type dt. Via Scheduler None
2016-10-14 20:53:00 DEBUG Scheduler location.time next time: 2016-10-14 20:54:00+02:00
2016-10-14 20:53:52 INFO _knx_heartbeat KNX: trying to connect
2016-10-14 20:53:52 DEBUG _knx_heartbeat KNX: sending connect request
2016-10-14 20:54:00 WARNING location.time Item location.time: value 1 does not match type dt. Via Scheduler None
2016-10-14 20:54:00 DEBUG Scheduler location.time next time: 2016-10-14 20:55:00+02:00
2016-10-14 20:54:52
