Hi. A couple of days ago, I switched from my old ETS3 files, to ETS 5. (and Gira expert 4.2 to 4.5, so also a new firmware on the homeserver)
Since then I'm having problems with the watercounter, like the topic said, it's a ARCUS-EDS IMPZ (from 2011 or something like that). Before the large update (ETS/HS) the counter worked flawlessly for many years, and it still is working like it should be.
But when I know reques the current usage value in ETS, it keeps giving me the same usage number for the last x-days, while on the meter itself (in between the water pipes) the correct higher number is visible.
I have no idea what could be wrong here? I assume I'm not having to update something in the IMPZ to make it's readout "compartible" with ETS5?
Any help welcome!
Any help welcome!
