Hello,
I'm sorry I don't speak German... And this forum is the best I could find in ETS / KNX... So this post will be in English if it's OK. Thank you to be indulgent with me :-).
Context :
Scenario giving the issue :
Question :
Hardware used (all is ABB Busch-Jägger):
ETS Programming :
Help would be GREATLY appreciated...
With my best regards,
Daric
------------------------- SCREEN SHOT OF PROGRAMMING ------------------------
--------------------------- Group addresses
--------------------------- ACTUATOR settings ---------------------------
Context :
- There is a button 'A' which turns ON/OFF 3 lights in a corridor at the first floor.
- There is a button 'B' which turns OFF all lights of the floor (used when I go down for example).
- I leave the lights ON in the corridor (so last time I pressed the corridor button 'A', it sent an ON telegram... Next one will be an OFF)
- I go out of the house, turning all lights OFF with the central function of button 'B'.
- When I come back and want to turn on the corridor again with button 'A', I have to press it 2 times (as if it was once for the OFF telegram -- but lights are already off --, and a second time to send the ON telegram).
Question :
- How can I program my buttons / adresses groups in order to have to press the button 'A' just once ?
- ACTUATOR : 6197/14-500 - Universal dimming actuator 6 x 315 W/VA up to 1 x 1890 W/VA* (http://www.knx-gebaeudesysteme.de/st...9AAC159431.htm)
This actuator is made of 6 channels each one of them being attributed to one light that I can turn On/Off or Dim.
- CONTROLER : 6342-101-500 priOn - Control element, 3gang (http://www.knx-gebaeudesysteme.de/st...9AAC168816.htm)
ETS Programming :
- Group addresses
- Switch ON / OFF in group address : 1/2/0
- Switch FeedBack in group address : 1/2/1
- Dimming in group address : 1/2/4
- Switch ON / OFF (among all other lights of the floor) in group address : 1/2/250
- Button 'A' assignations
- Switch ON/OFF (with sending value programmed to alternate between ON and OFF)
- Dimming
- Status
- Dimming
- Status
- Button 'B' assignations
- Switch ON/OFF (with sending value fixed to always send OFF)
- Actuator and flags
- One of the 3 lights that are in the corridor is on channel 4 of the actuator.
- This channel is, as said earlier linked to 2 group addresses :
- 1/2/0 : Switching ON/OFF with button 'A' --> The 'Sending' flag is at TRUE
- 1/2/250 : Switching OFF with button 'B' --> The 'Sending' flag is at FALSE
- The group address settings are :
- Pass through Line Couple : TRUE for both
- As I understood what is said as "central", is only there to facilitate the Copy function INSIDE the ETS program and has no influence on the elements and the bus itself.
Daric
