Habe eben eine E-Mail mit Informationen zur KNXperience erhalten.
Für alle die eine ETS Lizenz vergünstigt erwerben wollen, zwischen dem 28.09 und dem 02.10.2020 wird es eine Rabattaktion von 45% auf ETS5 Professional geben.
Hier die Info von der vFairs Veranstalltungsseite:
"How to redeem your vouchers?
At our Sales booth, on the central menu bar, choose the CHAT button to be connected to our Sales team. The special code you can use will be provided online. Copy it and save it the way your prefer.
How to use your special code?
To use the code you will need to login to our MyKNX platform where you need a personal account.Login in or create a new MyKNX account at https://my.knx.org
When logged in, choose the menu VOUCHERS
You can then enter the special code you have received
That code will add automatically our 3 special offers vouchers into your account
You can then start an order for the product indicated in the voucher of your choice.
After confirming the basket you can then select the voucher for that product via a drop-down menu and the reduction will be directly applied Continue the order procedure to finalise your purchase."
Hoffe das die Information von der Thematik hier reinpasst.
Aleksej
Aleksej
