das sieht soweit korrekt aus. Bis auf eine Kleinigkeit:
Zitat von Albert
Generating public/private rsa key pair.,
Created directory '/root/.ssh'.,
Your identification has been saved in /root/.ssh/id_rsa.,
Your public key has been saved in /root/.ssh/id_rsa.pub.,
The key fingerprint is:,
Please save the printed private RSA key and login using:,
"ssh -i ${savedkey} root@${ipaddress}",
Generating a 2048 bit RSA private key,
writing new private key to '/etc/pki/tls/private/edomi.key',
No value provided for Subject Attribute O, skipped,
No value provided for Subject Attribute OU, skipped,
Signature ok,
subject=/C=NZ/ST=Metropolis/L=Metropolis/CN=edomi,
Getting Private key,
HOSTIP not set, using edomi default settings.,
KNXGATEWAY not set, using edomi default settings.,
KNXACTIVE not set, using edomi default settings.,
WEBSOCKETPORT not set, using edomi default settings.,
Disabling heartbeat log output every second ... configure /usr/local/edomi/edomi.ini,
/root/start.sh: line 100: /usr/local/edomi/main/start.sh: Permission denied,
Exiting container with return value 0 to prevent Docker restarting it,
docker run --rm starwarsfan/edomi-docker:amd64-latest mysql --version
