Fernseher | LAN | Edomi
Hallo Andre,
hab den LBS gerade getestet. Einschalten hat funktioniert, wenn ich allerdings weitere Befehle sende bekomme ich folgende Fehlermeldung:
Code:[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]2018-08-14 15:35:54[/TD] [TD]960707[/TD] [TD]17996[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000309.php | Error: 2 | Line: 285 | fsockopen(): unable to connect to 192.168.84.26:0 (Failed to parse address "192.168.84.26") (746)[/TD] [/TR] [TR] [TD]2018-08-14 15:35:54[/TD] [TD]962704[/TD] [TD]17996[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Connection closed to 192.168.84.26 (746)[/TD] [/TR] [/TABLE] bzw: [TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]456836[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 15:44:56[/TD] [TD]456990[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: {"cmd":"power","value":"0"}[/TD] [/TR] [TR] [TD]2018-08-14 15:44:56[/TD] [TD]457123[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 15:44:56[/TD] [TD]468539[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Setting power to 0 (746)[/TD] [/TR] [TR] [TD]2018-08-14 15:44:56[/TD] [TD]470252[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000309.php | Error: 2 | Line: 285 | fsockopen(): unable to connect to 192.168.84.26:0 (Failed to parse address "192.168.84.26") (746)[/TD] [/TR] [TR] [TD]2018-08-14 15:44:56[/TD] [TD]472455[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Connection closed to 192.168.84.26 (746)[/TD] [/TR] [TR] [TD]2018-08-14 15:44:59[/TD] [TD]205073[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000309.php | Error: 2 | Line: 285 | fsockopen(): unable to connect to 192.168.84.26:0 (Failed to parse address "192.168.84.26") (746)[/TD] [/TR] [TR] [TD]2018-08-14 15:44:59[/TD] [TD]207122[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Connection closed to 192.168.84.26 (746)[/TD] [/TR] [TR] [TD]2018-08-14 15:44:59[/TD] [TD]212285[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000309.php | Error: 2 | Line: 285 | fsockopen(): unable to connect to 192.168.84.26:0 (Failed to parse address "192.168.84.26") (746)[/TD] [/TR] [TR] [TD]2018-08-14 15:44:59[/TD] [TD]214308[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Connection closed to 192.168.84.26 (746)[/TD] [/TR] [TR] [TD]2018-08-14 15:44:59[/TD] [TD]219664[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: File: /usr/local/edomi/www/data/liveproject/lbs/EXE19000309.php | Error: 2 | Line: 285 | fsockopen(): unable to connect to 192.168.84.26:0 (Failed to parse address "192.168.84.26") (746)[/TD] [/TR] [TR] [TD]2018-08-14 15:44:59[/TD] [TD]221642[/TD] [TD]32482[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Connection closed to 192.168.84.26 (746)[/TD] [/TR] [/TABLE]
Nach Projektaktivierung kommt noch folgende Fehlermeldung im Error-Log Edomi:
Code:2018-08-14 15:32:22 295358 ? 17996 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000309.php | Fehlercode: 2 | Zeile: 417 | fclose() expects parameter 1 to be resource, boolean given ERROR
PS: php-proccess hab ich installiert
Gruß Benjamin
Kommando zurück. Ich hab nicht gesehen, dass der Port nicht als default belegt war. Jetzt hab ich den Port konfiguriert und der LBS läuft.
getestet:
- Power on/off
- set volume 0-100
- volume up/down
- mute / unmute
- select input
- channel up/down
- Show notification message
Was nicht klappt: Select channel
danach wird der exec-daemon auch beendet.Code:2018-08-14 16:32:51 414024 ? 28878 Datei: /usr/local/edomi/www/data/liveproject/lbs/EXE19000309.php | Fehlercode: 1 | Zeile: 164 | Call to undefined method webOSTV::set_channel() FATALERROR
Edit: Pairing habe ich auch getestet und funktioniert.
Hi Benjamin,
der Port sollte eigentlich gemäß Definition auf 3000 vorbelegt sein. Aber vermutlich hast du ja nur ein Update des LBS gemacht und ihn nicht neu eingefügt. Durch die geänderte Eingangsreihenfolge, ist vermutlich damit bei dir der Port leer geblieben. Das set_channel() ist ein Bug, da es in der Klasse open_channel() heisst und der Aufruf mit set_channel() gemacht wurde. Ist behoben und wird jetzt hochgeladen. v0.5.1
VG
André
ja das Problem mit dem Port wird dadurch gekommen sein.
Ich hab jetzt noch weiter getestet:
Eingänge:
- Media play/stop/pause/rew/ffwd
- 3D mode on/off
Ausgänge:
- Power
- Volume
- Mute
- Channel number/name/type
- Input
funktionieren.
Eingänge:
- Start browser with URL ---> passiert bei mir nichts, Log:
Code:[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]2018-08-14 18:19:39[/TD] [TD]716912[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 18:19:39[/TD] [TD]717071[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: {"cmd":"open_browser","value":"192.168.84.8"}[/TD] [/TR] [TR] [TD]2018-08-14 18:19:39[/TD] [TD]717202[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 18:19:39[/TD] [TD]728813[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Open browser URL: 192.168.84.8 (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:39[/TD] [TD]732218[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THlCKWp1UW9HbzQwbFZaKQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:39[/TD] [TD]994827[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: WLSwU//VNXHciSrj3KegO40dr3k=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:39[/TD] [TD]998313[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: WLSwU//VNXHciSrj3KegO40dr3k=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:39[/TD] [TD]999984[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]001763[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]265945[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]269558[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: LG Login Response (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]269790[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]269967[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: "{\"type\":\"registered\",\"id\":\"register_0\",\"payload\":{\"client-key\":\"79d72f6382564c11fa8486443583cb70\"}}"[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]270101[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]271645[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: LG Client-Key successfully confirmed => LOGIN sucessfull (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]279735[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Sending command :{"id":"open_browser","type":"request","uri":"ssap://system.launcher/open","payload":{"target":"192.168.84.8"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]405195[/TD] [TD]30181[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5]: LG WebOS LBS started (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]434803[/TD] [TD]30181[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5]: Daemon is running with PID: 30549 (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]438179[/TD] [TD]30181[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5]: LG WebOS LBS ended (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]542613[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: send() - RAW Response received: �~�{"type":"error","id":"open_browser","error":"500 Application error","payload":{"returnValue":false,"errorCode":-6,"errorText":"No handler for 192.168.84.8"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:40[/TD] [TD]546236[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Command response : {"type":"error","id":"open_browser","error":"500 Application error","payload":{"returnValue":false,"errorCode":-6,"errorText":"No handler for 192.168.84.8"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:52[/TD] [TD]000703[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THlCKWp1UW9HbzQwbFZaKQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:52[/TD] [TD]263300[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: WLSwU//VNXHciSrj3KegO40dr3k=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:52[/TD] [TD]267035[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: WLSwU//VNXHciSrj3KegO40dr3k=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:52[/TD] [TD]269253[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:52[/TD] [TD]271290[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:52[/TD] [TD]536226[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 18:19:52[/TD] [TD]540039[/TD] [TD]30549[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5]: LG Login Response (746)[/TD] [/TR] [/TABLE]
- Start/Close app ---> noch nichts getestet da app List leer
- Play youtube video by ID/URL (does not work yet. Currently it starts only the youtube app) startet bei mir auch nur YouTube APP
Ausgänge:
- RAW JSON list of channels, inputs, apps, services, SW info ---> bringt bei mir ein Error:
Code:{"type":"error","id":"get_app_list","error":"401 insufficient permissions","payload":{}}
select Channel gerade mit 0.5.1 getestet ---> funktioniert bei mir leider nicht Log:
Code:[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]018-08-14 19:04:19[/TD] [TD]182966[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 19:04:19[/TD] [TD]183125[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: "{\"type\":\"registered\",\"id\":\"register_0\",\"payload\":{\"client-key\":\"79d72f6382564c11fa8486443583cb70\"}}"[/TD] [/TR] [TR] [TD]2018-08-14 19:04:19[/TD] [TD]183248[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 19:04:19[/TD] [TD]184840[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: LG Client-Key successfully confirmed => LOGIN sucessfull (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:19[/TD] [TD]192476[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: Sending command :{"id":"open_channel","type":"request","uri":"ssap://tv/openChannel","payload":{"channelId":"1"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:19[/TD] [TD]236399[/TD] [TD]20023[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.1]: LG WebOS LBS started (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:19[/TD] [TD]265717[/TD] [TD]20023[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.1]: Daemon is running with PID: 20398 (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:19[/TD] [TD]269098[/TD] [TD]20023[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.1]: LG WebOS LBS ended (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:19[/TD] [TD]455194[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: send() - RAW Response received: �~�{"type":"error","id":"open_channel","error":"500 Application error","payload":{"returnValue":false,"errorCode":-1000,"errorText":"invalid channel id"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:19[/TD] [TD]458683[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: Command response : {"type":"error","id":"open_channel","error":"500 Application error","payload":{"returnValue":false,"errorCode":-1000,"errorText":"invalid channel id"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:31[/TD] [TD]115724[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: T1ImQjQ1YnNTKEtiZGpKOQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:31[/TD] [TD]378200[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: kXN+fT+dOw6hyOy8+ljWPAb0aZA=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:31[/TD] [TD]381315[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: kXN+fT+dOw6hyOy8+ljWPAb0aZA=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:31[/TD] [TD]382802[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:31[/TD] [TD]384900[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:31[/TD] [TD]648967[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 19:04:31[/TD] [TD]652905[/TD] [TD]20398[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.1]: LG Login Response (746)[/TD] [/TR] [/TABLE]
Browser habe ich gerade nochmal mit "http://www.spiegel.de" getestet. Funktioniert. Hast du auch mal mit "http://" versucht?
Channel-ID ist die ID aus der Channel Liste, nicht die normale Kanalnummer. Das steht ja auch in deinem Log: Invalid Channel ID.
Seltsam, dass die RAW Listen bei die leer bleiben. Das sieht so aus, als wäre die Anmeldung dann nicht mehr gültig. Ich mache aber bei jeder Abfrage ein explizites Connect und am Ende ein Disconnect, so dass dies gar nicht auftreten sollte.
In der v0.5.2 macht eine 1 auf E31 ein explizites Update inkl. der RAW Listen. Das regelmäßig Update, welches all E32 Sekunden gemacht wird, berücksichtigt nur die Statusausgänge, die wirklich dynamisch sind, d.h. Power, Volume, Mute, Channel number/name/type, Input.
Browser lag wirklich an dem "http://", funktioniert jetzt bestens.
Channel List bleibt bei mir leider auch leer. Deswegen weiß ich auch keine ID, ich hatte gedacht es handelt sich um die Kanalnummer.
Input List bleibt übrigens auch leer.
Raw-Listen sind nach dem update auf 0.5.2 immer noch leer.
Ja habe ich gemacht, hier auch mal ein Auszug aus dem Log. Listen bleiben allerdings leer.
Code:[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]182270[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]182420[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: {"cmd":"status"}[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]182545[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]195086[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Update of status values... (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]211327[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THRySCRMdEM2fSE0YWF1YQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]474019[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]478012[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]479650[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]482000[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]746241[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]749839[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Login Response (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]750087[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]750233[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: "{\"type\":\"registered\",\"id\":\"register_0\",\"payload\":{\"client-key\":\"79d72f6382564c11fa8486443583cb70\"}}"[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]750361[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]751936[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Client-Key successfully confirmed => LOGIN sucessfull (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]759794[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending command :{"id":"get_volume","type":"request","uri":"ssap://audio/getVolume"} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]808114[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS started (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]839859[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: Daemon is running with PID: 28155 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:35[/TD] [TD]841769[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS ended (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]022619[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �~�{"type":"response","id":"get_volume","payload":{"returnValue":true,"scenario":"mastervolume_ext_speaker_urcu_oss","volume":-1,"muted":false}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]026716[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Command response : {"type":"response","id":"get_volume","payload":{"returnValue":true,"scenario":"mastervolume_ext_speaker_urcu_oss","volume":-1,"muted":false}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]033709[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THRySCRMdEM2fSE0YWF1YQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]296452[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]300046[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]301685[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]303240[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]567374[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]570851[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Login Response (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]571074[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]571240[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: "{\"type\":\"registered\",\"id\":\"register_0\",\"payload\":{\"client-key\":\"79d72f6382564c11fa8486443583cb70\"}}"[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]571368[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]572906[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Client-Key successfully confirmed => LOGIN sucessfull (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]580534[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending command :{"id":"get_channel","type":"request","uri":"ssap://tv/getCurrentChannel"} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]652657[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS started (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]684267[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: Daemon is running with PID: 28155 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]686244[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS ended (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]843549[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �~Z{"type":"response","id":"get_channel","payload":{"channelId":"7_2_3_3_1057_61200_1","signalChannelId":"1057_61200_1","channelModeId":2,"channelModeName":"Satellite","channelTypeId":6,"channelTypeName":"Satellite Digital TV","channelNumber":"3","channelName":"RTL HD","physicalNumber":2,"isSkipped":false,"isLocked":false,"isDescrambled":false,"isScrambled":true,"isFineTuned":false,"isInvisible":false,"isHEVCChannel":false,"favoriteGroup":null,"hybridtvType":"HBBTV","dualChannel":{"dualChannelId":null,"dualChannelTypeId":null,"dualChannelTypeName":null,"dualChannelNumber":null},"returnValue":true}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]847584[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Command response : {"type":"response","id":"get_channel","payload":{"channelId":"7_2_3_3_1057_61200_1","signalChannelId":"1057_61200_1","channelModeId":2,"channelModeName":"Satellite","channelTypeId":6,"channelTypeName":"Satellite Digital TV","channelNumber":"3","channelName":"RTL HD","physicalNumber":2,"isSkipped":false,"isLocked":false,"isDescrambled":false,"isScrambled":true,"isFineTuned":false,"isInvisible":false,"isHEVCChannel":false,"favoriteGroup":null,"hybridtvType":"HBBTV","dualChannel":{"dualChannelId":null,"dualChannelTypeId":null,"dualChannelTypeName":null,"dualChannelNumber":null},"returnValue":true}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:36[/TD] [TD]854684[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THRySCRMdEM2fSE0YWF1YQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]117333[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]120950[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]122637[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]124201[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]389545[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]392934[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Login Response (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]393140[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]393285[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: "{\"type\":\"registered\",\"id\":\"register_0\",\"payload\":{\"client-key\":\"79d72f6382564c11fa8486443583cb70\"}}"[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]393412[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]395076[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Client-Key successfully confirmed => LOGIN sucessfull (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]402230[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending command :{"id":"get_app_info","type":"request","uri":"ssap://com.webos.applicationManager/getForegroundAppInfo"} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]587877[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS started (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]620670[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: Daemon is running with PID: 28155 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]622478[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS ended (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]664994[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �~�{"type":"response","id":"get_app_info","payload":{"appId":"com.webos.app.livetv","returnValue":true,"windowId":"","processId":"n-843"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]668664[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Command response : {"type":"response","id":"get_app_info","payload":{"appId":"com.webos.app.livetv","returnValue":true,"windowId":"","processId":"n-843"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]674190[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THRySCRMdEM2fSE0YWF1YQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]936736[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]941000[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]942604[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:37[/TD] [TD]955213[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]223048[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]226203[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Login Response (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]226382[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]226520[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: "{\"type\":\"registered\",\"id\":\"register_0\",\"payload\":{\"client-key\":\"79d72f6382564c11fa8486443583cb70\"}}"[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]226648[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]228256[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Client-Key successfully confirmed => LOGIN sucessfull (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]235599[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending command :{"id":"get_chanel_list","type":"request","uri":"ssap://tv/getChannelList"} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]429502[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS started (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]457911[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: Daemon is running with PID: 28155 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]459697[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS ended (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]498323[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]499914[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Error sending command: {"id":"get_chanel_list","type":"request","uri":"ssap://tv/getChannelList"} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]508308[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THRySCRMdEM2fSE0YWF1YQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]771516[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]775162[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]777162[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:38[/TD] [TD]778753[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]043093[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]046550[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Login Response (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]046771[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]046942[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: "{\"type\":\"registered\",\"id\":\"register_0\",\"payload\":{\"client-key\":\"79d72f6382564c11fa8486443583cb70\"}}"[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]047075[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]048595[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Client-Key successfully confirmed => LOGIN sucessfull (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]056891[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending command :{"id":"get_input_list","type":"request","uri":"ssap://tv/getExternalInputList"} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]101658[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS started (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]132304[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: Daemon is running with PID: 28155 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]134377[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS ended (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]319434[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]321105[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Error sending command: {"id":"get_input_list","type":"request","uri":"ssap://tv/getExternalInputList"} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]331084[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THRySCRMdEM2fSE0YWF1YQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]596142[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]603251[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]605478[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]607707[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]872411[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]876004[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Login Response (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]876215[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]876364[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: "{\"type\":\"registered\",\"id\":\"register_0\",\"payload\":{\"client-key\":\"79d72f6382564c11fa8486443583cb70\"}}"[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]876497[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]878086[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Client-Key successfully confirmed => LOGIN sucessfull (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:39[/TD] [TD]887195[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending command :{"id":"get_app_list","type":"request","uri":"ssap://com.webos.applicationManager/listLaunchPoints"} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]026168[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS started (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]054816[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: Daemon is running with PID: 28155 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]057147[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS ended (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]150175[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �X{"type":"error","id":"get_app_list","error":"401 insufficient permissions","payload":{}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]155870[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Command response : {"type":"error","id":"get_app_list","error":"401 insufficient permissions","payload":{}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]161350[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THRySCRMdEM2fSE0YWF1YQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]424123[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]428122[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]429789[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]431329[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]695522[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]699590[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Login Response (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]699819[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]699960[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: "{\"type\":\"registered\",\"id\":\"register_0\",\"payload\":{\"client-key\":\"79d72f6382564c11fa8486443583cb70\"}}"[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]700668[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]702379[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Client-Key successfully confirmed => LOGIN sucessfull (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]710516[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending command :{"id":"get_service_list","type":"request","uri":"ssap://api/getServiceList"} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]761464[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS started (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]794552[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: Daemon is running with PID: 28155 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]796395[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS ended (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]973680[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �~�{"type":"response","id":"get_service_list","payload":{"services":[{"name":"api","version":1},{"name":"audio","version":1},{"name":"media.controls","version":1},{"name":"media.viewer","version":1},{"name":"pairing","version":1},{"name":"system","version":1},{"name":"system.launcher","version":1},{"name":"system.notifications","version":1},{"name":"tv","version":1},{"name":"webapp","version":2}],"returnValue":true}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]977224[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Command response : {"type":"response","id":"get_service_list","payload":{"services":[{"name":"api","version":1},{"name":"audio","version":1},{"name":"media.controls","version":1},{"name":"media.viewer","version":1},{"name":"pairing","version":1},{"name":"system","version":1},{"name":"system.launcher","version":1},{"name":"system.notifications","version":1},{"name":"tv","version":1},{"name":"webapp","version":2}],"returnValue":true}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:40[/TD] [TD]983409[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THRySCRMdEM2fSE0YWF1YQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]246454[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]251372[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]253740[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]255880[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]519730[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]522888[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Login Response (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]523091[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]523238[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: "{\"type\":\"registered\",\"id\":\"register_0\",\"payload\":{\"client-key\":\"79d72f6382564c11fa8486443583cb70\"}}"[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]523366[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]524796[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Client-Key successfully confirmed => LOGIN sucessfull (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]531847[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending command :{"id":"sw_info","type":"request","uri":"ssap://com.webos.service.update/getCurrentSWInformation"} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]696271[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS started (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]728543[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: Daemon is running with PID: 28155 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]731318[/TD] [TD]27779[/TD] [TD]debug [/TD] [TD]LBS19000309 [v0.5.2]: LG WebOS LBS ended (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]794374[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �S{"type":"error","id":"sw_info","error":"401 insufficient permissions","payload":{}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]797676[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Command response : {"type":"error","id":"sw_info","error":"401 insufficient permissions","payload":{}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:41[/TD] [TD]817518[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending WS handshake: GET / HTTP/1.1[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Version: 13[CR][LF]Sec-WebSocket-Key: THRySCRMdEM2fSE0YWF1YQ==[CR][LF]Host: 192.168.84.26:3000[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:42[/TD] [TD]080224[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:42[/TD] [TD]083862[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: WS Handshake Response: HTTP/1.1 101 Switching Protocols[CR][LF]Upgrade: websocket[CR][LF]Connection: Upgrade[CR][LF]Sec-WebSocket-Accept: welWH+Ve/WXIL66fua9Jki0Nc0U=[CR][LF][CR][LF] (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:42[/TD] [TD]085832[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sucessfull WS connection to 192.168.84.26:3000 (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:42[/TD] [TD]087491[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: Sending LG handshake[LF]{"type":"register","id":"register_0","payload":{"forcePairing":false,"pairingType":"PROMPT","client-key":"79d72f6382564c11fa8486443583cb70","manifest":{"manifestVersion":1,"appVersion":"1.1","signed":{"created":"20140509","appId":"com.lge.test","vendorId":"com.lge","localizedAppNames":{"":"LG Remote App","ko-KR":"??? ?","zxx-XX":"?? R??ot? A??"},"localizedVendorNames":{"":"LG Electronics"},"permissions":["TEST_SECURE","CONTROL_INPUT_TEXT","CONTROL_MOUSE_AND_KEYBOARD","READ_INSTALLED_APPS","READ_LGE_SDX","READ_NOTIFICATIONS","SEARCH","WRITE_SETTINGS","WRITE_NOTIFICATION_ALERT","CONTROL_POWER","READ_CURRENT_CHANNEL","READ_RUNNING_APPS","READ_UPDATE_INFO","UPDATE_FROM_REMOTE_APP","READ_LGE_TV_INPUT_EVENTS","READ_TV_CURRENT_TIME"],"serial":"2f930e2d2cfe083771f68e4fe7bb07"},"permissions":["LAUNCH","LAUNCH_WEBAPP","APP_TO_APP","CLOSE","TEST_OPEN","TEST_PROTECTED","CONTROL_AUDIO","CONTROL_DISPLAY","CONTROL_INPUT_JOYSTICK","CONTROL_INPUT_MEDIA_RECORDING","CONTROL_INPUT_MEDIA_PLAYBACK","CONTROL_INPUT_TV","CONTROL_POWER","READ_APP_STATUS","READ_CURRENT_CHANNEL","READ_INPUT_DEVICE_LIST","READ_NETWORK_STATE","READ_RUNNING_APPS","READ_TV_CHANNEL_LIST","WRITE_NOTIFICATION_TOAST","READ_POWER_STATE","READ_COUNTRY_INFO"],"signatures":[{"signatureVersion":1,"signature":"eyJhbGdvcml0aG0iOiJSU0EtU0hBMjU2Iiwia2V5SWQiOiJ0ZXN0LXNpZ25pbmctY2VydCIsInNpZ25hdHVyZVZlcnNpb24iOjF9.hrVRgjCwXVvE2OOSpDZ58hR+59aFNwYDyjQgKk3auukd7pcegmE2CzPCa0bJ0ZsRAcKkCTJrWo5iDzNhMBWRyaMOv5zWSrthlf7G128qvIlpMT0YNY+n/FaOHE73uLrS/g7swl3/qH/BGFG2Hu4RlL48eb3lLKqTt2xKHdCs6Cd4RMfJPYnzgvI4BNrFUKsjkcu+WD4OO2A27Pq1n50cMchmcaXadJhGrOqH5YmHdOCj5NSHzJYrsW0HPlpuAx/ECMeIZYDh6RMqaFM2DXzdKX9NmmyqzJ3o/0lkk/N97gfVRLW5hA29yeAwaCViZNCP8iC9aO0q9fQojoa7NQnAtw=="}]}}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:42[/TD] [TD]351541[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: send() - RAW Response received: �c{"type":"registered","id":"register_0","payload":{"client-key":"79d72f6382564c11fa8486443583cb70"}} (746)[/TD] [/TR] [TR] [TD]2018-08-14 21:37:42[/TD] [TD]355149[/TD] [TD]28155[/TD] [TD]debug [/TD] [TD]EXE19000309 [v0.5.2]: LG Login Response (746)[/TD] [/TR] [/TABLE]
Hmm, so langsam gehen mir die Ideen aus.
Ich werde morgen nochmal mit der Version aus dem Downloadportal bei mir testen. Evtl. ist das was mit der Zeichenkodierung in dem Pairing String beim Upload schief gelaufen.
Vielleicht gibts ja noch andere mit LG WebOS TV hier, die den LBS mal testen können, um diesem Phänomen auf die Spur zu kommen.
