Installation eibd unter CentOS 7 funktioniert nicht
    Hallöchen, bei mir läuft es leider nicht so rund...
    Das war der Output bisher:
    [root@edomi7 ~]# systemctl status eibd.service
    ● eibd.service - EIB Daemon
    Loaded: loaded (/etc/systemd/system/eibd.service; enabled; vendor preset: dis abled)
    Active: failed (Result: signal) since Di 2021-12-28 18:27:44 CET; 34s ago
    Process: 14968 ExecStart=/usr/local/bin/eibd -d -D -T -S -i --no-tunnel-client -queuing --eibaddr=1.1.249 ipt:192.168.2.39 (code=killed, signal=SEGV)
    Dez 28 18:27:44 edomi7 systemd[1]: Starting EIB Daemon...
    Dez 28 18:27:44 edomi7 systemd[1]: eibd.service: control process exited, co...11
    Dez 28 18:27:44 edomi7 systemd[1]: Failed to start EIB Daemon.
    Dez 28 18:27:44 edomi7 systemd[1]: Unit eibd.service entered failed state.
    Dez 28 18:27:44 edomi7 systemd[1]: eibd.service failed.
    Hint: Some lines were ellipsized, use -l to show in full.
    Loaded: loaded (/etc/systemd/system/eibd.service; enabled; vendor preset: disabled)
    Active: failed (Result: signal) since Di 2021-12-28 18:27:44 CET; 59s ago
    Process: 14968 ExecStart=/usr/local/bin/eibd -d -D -T -S -i --no-tunnel-client-queuing --eibaddr=1.1.249 ipt:192.168.2.39 (code=killed, s ignal=SEGV)
    [root@edomi7 ~]# journalctl -xe
    -- Defined-By: systemd
    -- Support: http://lists.freedesktop.org/mailman.../systemd-devel
    -- Unit eibd.service has failed.
    -- The result is failed.
    Dez 28 18:32:31 edomi7 systemd[1]: Unit eibd.service entered failed state.
    Dez 28 18:32:31 edomi7 systemd[1]: eibd.service failed.
    Dez 28 18:32:31 edomi7 polkitd[3068]: Unregistered Authentication Agent for unix-process:4452:5102 (system bus name :1.28, object path /org
    Dez 28 18:32:37 edomi7 systemd[1]: Starting Stop Read-Ahead Data Collection...
    -- Subject: Unit systemd-readahead-done.service has begun start-up
    -- Unit systemd-readahead-done.service has begun starting up.
    Dez 28 18:32:37 edomi7 systemd[1]: Started Stop Read-Ahead Data Collection.
    -- Subject: Unit systemd-readahead-done.service has finished start-up
    -- Unit systemd-readahead-done.service has finished starting up.
    -- The start-up result is done.
    lines 2116-2138/2138 (END)
    Hat jemand eine Ahnung was ich damit anfangen kann...bin nicht wirklich der Linux crack und habe mich eigentlich nur von Schritt zu Schritt durchgearbeitet
    Gruss Jan
    Zuletzt geändert von Surfikus; 29.12.2021, 09:05.
    Installation:
    HS2, BIQ+RTR, DALI-GW GE141, Visu über 19" u. 15" Touch, Gira MT701CT, Russound CAV6.6, Dreambox 7020S, iPhone, iPad, Nomos
      hast Du einen Router oder eine IP Schnittstelle? ipt:192.168.2.39 ist die Config für den Router IP Interface müsste ip:192.168.2.39 sein. Ist aber nur aus dem Gedächtnis. Für die Startparameter gibts hier sicher den ein oder anderen Thread.
        Habe eine Schnittstelle und eben gerade nochmals nur mit IP:... probiert - selber Fehler. Muss mal schauen was ich an den Startparametern noch anpassen kann
        Installation:
          Das Gedächnis kann leider täuschen. ipt: für Tunneladrese, ip: für Multicast. 192.168.2.39 kann nur eine Tunneladresse sein.
          Fürs Debugging würde ich empfehlen, die Services zuerst zu stoppen und dann die Kommandozeile mit zusätzlichen Debugging-Werten in der Shell zu starten.
          EIB/KNX, VISU mit knxd + linknx + knxweb, Steuerbefehle via SMS und Email mit postfix + procmail
            Na schau, aber dafür gibts ja auch noch den ein oder anderen User hier...
              Hmmm, ok, ich versuche das mal umzusetzen was ihr da meint 🙈
              Installation:
