Hallöchen, bei mir läuft es leider nicht so rund...
Das war der Output bisher:
[root@edomi7 ~]# systemctl status eibd.service
● eibd.service - EIB Daemon
Loaded: loaded (/etc/systemd/system/eibd.service; enabled; vendor preset: dis abled)
Active: failed (Result: signal) since Di 2021-12-28 18:27:44 CET; 34s ago
Process: 14968 ExecStart=/usr/local/bin/eibd -d -D -T -S -i --no-tunnel-client -queuing --eibaddr=1.1.249 ipt:192.168.2.39 (code=killed, signal=SEGV)
Dez 28 18:27:44 edomi7 systemd[1]: Starting EIB Daemon...
Dez 28 18:27:44 edomi7 systemd[1]: eibd.service: control process exited, co...11
Dez 28 18:27:44 edomi7 systemd[1]: Failed to start EIB Daemon.
Dez 28 18:27:44 edomi7 systemd[1]: Unit eibd.service entered failed state.
Dez 28 18:27:44 edomi7 systemd[1]: eibd.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
Loaded: loaded (/etc/systemd/system/eibd.service; enabled; vendor preset: disabled)
Active: failed (Result: signal) since Di 2021-12-28 18:27:44 CET; 59s ago
Process: 14968 ExecStart=/usr/local/bin/eibd -d -D -T -S -i --no-tunnel-client-queuing --eibaddr=1.1.249 ipt:192.168.2.39 (code=killed, s ignal=SEGV)
[root@edomi7 ~]# journalctl -xe
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman.../systemd-devel
-- Unit eibd.service has failed.
-- The result is failed.
Dez 28 18:32:31 edomi7 systemd[1]: Unit eibd.service entered failed state.
Dez 28 18:32:31 edomi7 systemd[1]: eibd.service failed.
Dez 28 18:32:31 edomi7 polkitd[3068]: Unregistered Authentication Agent for unix-process:4452:5102 (system bus name :1.28, object path /org
Dez 28 18:32:37 edomi7 systemd[1]: Starting Stop Read-Ahead Data Collection...
-- Subject: Unit systemd-readahead-done.service has begun start-up
-- Unit systemd-readahead-done.service has begun starting up.
Dez 28 18:32:37 edomi7 systemd[1]: Started Stop Read-Ahead Data Collection.
-- Subject: Unit systemd-readahead-done.service has finished start-up
-- Unit systemd-readahead-done.service has finished starting up.
-- The start-up result is done.
lines 2116-2138/2138 (END)
Hat jemand eine Ahnung was ich damit anfangen kann...bin nicht wirklich der Linux crack und habe mich eigentlich nur von Schritt zu Schritt durchgearbeitet
Gruss Jan
Gruss Jan
