PHP-Code:
function LB_LBSID_DEBUG($id,$a) {writeToTraceLog(0,true,"LBSLBSID($id): ".$a);}
###[EXEC]###
<?php
require(dirname(__FILE__)."/../../../../main/include/php/incl_lbsexec.php");
sql_connect();
if ($E=getLogicEingangDataAll($id)) {
$str = file_get_contents('http://10.0.100.150/%7Edariusz/track.json');
$track = json_decode($str,true);
setLogicLinkAusgang($id,1,$track['name']);
writeToTraceLog(0,true,'iTunes | A01 | Titel: '.$track['name']);
// if ($E[2]['value'] == 1) {LB_LBSID_DEBUG($id,'iTunes | A01 | Titel: '.$track['name']);}
setLogicLinkAusgang($id,2,$track['album']);
setLogicLinkAusgang($id,3,$track['genre']);
setLogicLinkAusgang($id,4,$track['composer']);
setLogicLinkAusgang($id,5,$track['artist']);
sql_disconnect();
function LB_LBSID_DEBUG($id,$a) {writeToTraceLog(0,true,'LBSLBSID($id): '.$a);}
###[/EXEC]###<?php
function LB_LBSID($id) {
// function LB_LBSID_DEBUG($id,$a) {writeToTraceLog(0,true,'LBSLBSID($id): '.$a);}
if ($E[1]['refresh']) {
// if ($E[2]['value'] == 1) {LB_LBSID_DEBUG($id,'iTunes | E01 | Trigger Aktiv: '.$E[1]['value']);}
writeToTraceLog(0,true,'iTunes | E01 | Trigger Aktiv: '.$E[1]['value']);
writeToTraceLog(0,true,'iTunes | E02 | Debug Aktiv: '.$E[2]['value']);
callLogicFunctionExec(LBSID,$id);
}<?php
sql_connect();
writeToTraceLog(0,true,'URL= '.$str);
sql_disconnect();
?><?php
sql_connect();
sql_disconnect();
?><?php
}function LB_LBSID_DEBUG($id,$a) {writeToTraceLog(0,true,'LBSLBSID($id): '.$a);}
function LB_LBSID_DEBUG($id,$a) {writeToTraceLog(0,true,'LBSLBSID('.$id.'): '.$a);}
