das letzte Update eines LBS war ja auch am 30.01., dein Log fängt aber erst später an.
LBS19000303 - Telegram Contact I LBS19000304 - Telegram Receiver I LBS19000645 - Telegram Command Validator
Nein, es scheint so als würde der Text von Notification (A4) über das iKO am Contact nicht ankommen … Alle anderen Nachrichten die so konfiguriert sind kommen an.
Log aus Contact habe ich keinen aus der Zeit wie Notification, aber wenn ich jetzt meine Testlampe schalte:
Code:[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]227655[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]229005[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]231913[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]232434[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]240633[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]241051[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]242516[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]244101[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]248023[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]248473[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: Create Message Queue with ID: 2868cff6[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]248732[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: command started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]248776[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: photo => /usr/local/edomi/www/data/project/visu/img/img-6.jpg[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]249017[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]249598[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]249995[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: Create Message Queue with ID: 5faebda2[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]250247[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: command started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]250289[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: photo => /usr/local/edomi/www/data/project/visu/img/img-6.jpg[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]250529[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]263534[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]264065[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: Create Message Queue with ID: 2868cff6[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]264309[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: command started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]264353[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: text => Das <b>Licht</b> in Vorzimmer/Eingang wurde <b>EINGESCHALTET</b>[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]264580[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]265396[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]265835[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: Create Message Queue with ID: 5faebda2[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]266072[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: command started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]266113[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: text => Das <b>Licht</b> in Vorzimmer/Eingang wurde <b>EINGESCHALTET</b>[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]266339[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]295551[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]296129[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Command:photo[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]298286[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]299581[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Command:photo[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]810708[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram photo message sent: /usr/local/edomi/www/data/project/visu/img/img-6.jpg (255470302)[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]811830[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution finished[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]913768[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:27[/TD] [TD]914467[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Command:text[/TD] [/TR] [TR] [TD]2017-02-01 22:44:28[/TD] [TD]255595[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram text message sent: Das <b>Licht</b> in Vorzimmer/Eingang wurde <b>EINGESCHALTET</b> (255470302)[/TD] [/TR] [TR] [TD]2017-02-01 22:44:28[/TD] [TD]256367[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution finished[/TD] [/TR] [TR] [TD]2017-02-01 22:44:28[/TD] [TD]299092[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Failed to send Telegram photo message: /usr/local/edomi/www/data/project/visu/img/img-6.jpg (247929879)[/TD] [/TR] [TR] [TD]2017-02-01 22:44:28[/TD] [TD]300157[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution finished[/TD] [/TR] [TR] [TD]2017-02-01 22:44:28[/TD] [TD]402168[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:28[/TD] [TD]403036[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Command:text[/TD] [/TR] [TR] [TD]2017-02-01 22:44:28[/TD] [TD]623219[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Failed to send Telegram text message: Das <b>Licht</b> in Vorzimmer/Eingang wurde <b>EINGESCHALTET</b> (247929879)[/TD] [/TR] [TR] [TD]2017-02-01 22:44:28[/TD] [TD]624453[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution finished[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]284540[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]284934[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]285737[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]286077[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]287641[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]287920[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]288465[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]288736[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]290296[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]290684[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: Create Message Queue with ID: 2868cff6[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]291201[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: command started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]291248[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: photo => /usr/local/edomi/www/data/project/visu/img/img-5.jpg[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]291476[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]292040[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]292419[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: Create Message Queue with ID: 5faebda2[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]292655[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: command started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]292696[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: photo => /usr/local/edomi/www/data/project/visu/img/img-5.jpg[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]293154[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]294703[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]295016[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: Create Message Queue with ID: 2868cff6[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]295259[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: command started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]295301[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: text => Das <b>Licht</b> in Vorzimmer/Ausgang wurde <b>AUSGESCHALTET</b>[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]295526[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]296070[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]296374[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: Create Message Queue with ID: 5faebda2[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]296607[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: command started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]296648[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: text => Das <b>Licht</b> in Vorzimmer/Ausgang wurde <b>AUSGESCHALTET</b>[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]296930[/TD] [TD]19408[/TD] [TD]debug [/TD] [TD]LBS19000303 [v0.7]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]361507[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]362052[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Command:photo[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]365120[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]365547[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Command:photo[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]773468[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Failed to send Telegram photo message: /usr/local/edomi/www/data/project/visu/img/img-5.jpg (247929879)[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]774501[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution finished[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]843566[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram photo message sent: /usr/local/edomi/www/data/project/visu/img/img-5.jpg (255470302)[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]844418[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution finished[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]875684[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]876071[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Command:text[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]946399[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution started[/TD] [/TR] [TR] [TD]2017-02-01 22:44:37[/TD] [TD]946970[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Command:text[/TD] [/TR] [TR] [TD]2017-02-01 22:44:38[/TD] [TD]097337[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Failed to send Telegram text message: Das <b>Licht</b> in Vorzimmer/Ausgang wurde <b>AUSGESCHALTET</b> (247929879)[/TD] [/TR] [TR] [TD]2017-02-01 22:44:38[/TD] [TD]098283[/TD] [TD]19419[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution finished[/TD] [/TR] [TR] [TD]2017-02-01 22:44:38[/TD] [TD]294224[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram text message sent: Das <b>Licht</b> in Vorzimmer/Ausgang wurde <b>AUSGESCHALTET</b> (255470302)[/TD] [/TR] [TR] [TD]2017-02-01 22:44:38[/TD] [TD]294990[/TD] [TD]19417[/TD] [TD]debug [/TD] [TD]EXE19000303 [v0.7]: Telegram message execution finished[/TD] [/TR] [/TABLE]
Sorry, ich meinte eher den Telegram-Contact.
Du hattest doch gesagt, dass der Output vom Notification LBS (A4) am Telegram Contact ankommt. Richtig?
Ich müsste mal die Logs des Telegram Contacts sehen, wenn eine Nachricht vom Notification LBS ankommt.
Notifications:
Code:[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]2017-02-01 15:43:55[/TD] [TD]510926[/TD] [TD]2745[/TD] [TD]debug [/TD] [TD]EXE19000649 [v0.1]: Received last edit timestamp: 1485960222[/TD] [/TR] [TR] [TD]2017-02-01 15:43:55[/TD] [TD]511727[/TD] [TD]2745[/TD] [TD]debug [/TD] [TD]EXE19000649 [v0.1]: Last Edit Time : 1485960222[/TD] [/TR] [TR] [TD]2017-02-01 15:43:55[/TD] [TD]512984[/TD] [TD]2745[/TD] [TD]debug [/TD] [TD]EXE19000649 [v0.1]: Last Update Time: 1485947834[/TD] [/TR] [TR] [TD]2017-02-01 15:43:55[/TD] [TD]841872[/TD] [TD]2745[/TD] [TD]debug [/TD] [TD]EXE19000649 [v0.1]: Installed LBS: ["12000000","12000001","12000002","12000003","12000004","12000005","12000008","12000010","12000011","12000012","12000013","12000014","12000015","12000100","13000011","13000012","13000013","13000014","13000020","13000021","13000022","13000023","13000026","13000030","13000031","13000039","13000120","14000020","14000021","14000022","14000023","14000024","14000025","14000028","14000029","14000100","15000020","15000032","15000033","15000034","15000040","15000041","15000042","15000043","15000044","15000045","15000046","15000050","15000051","15000052","15000053","15000069","15000070","15000071","15000100","15000110","16000001","16000100","16000101","16000109","16000110","16000111","16000112","16000113","16000114","16000115","16000116","16000117","16000130","17000001","17000002","17000200","17000210","17000220","17000221","17000225","18000001","18000003","18000005","18000010","18000020","18000060","18000061","18000062","18000063","18000100","19000001","19000002","19000003","19000004","19000005","19000006","19000007","19000008","19000009","19000042","19000070","19000071","19000303","19000304","19000649","19000963","19000964","19900001","19900011"][/TD] [/TR] [TR] [TD]2017-02-01 15:43:55[/TD] [TD]842904[/TD] [TD]2745[/TD] [TD]debug [/TD] [TD]EXE19000649 [v0.1]: Used LBS: ["12000010","12000011","12000012","12000015","13000011","13000012","13000013","13000014","13000030","13000031","14000020","14000021","14000023","14000024","14000025","15000040","16000117","17000210","19000001","19000005","19000006","19000007","19000008","19000042","19000070","19000071","19000303","19000304","19000649","19000963"][/TD] [/TR] [TR] [TD]2017-02-01 15:43:56[/TD] [TD]024688[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 15:43:56[/TD] [TD]025527[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 15:44:56[/TD] [TD]065407[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 15:44:56[/TD] [TD]066310[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 15:45:56[/TD] [TD]120138[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 15:45:56[/TD] [TD]121088[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 15:46:56[/TD] [TD]162081[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 15:46:56[/TD] [TD]162815[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 15:47:56[/TD] [TD]225826[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 15:47:56[/TD] [TD]226658[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 15:48:56[/TD] [TD]244652[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 15:48:56[/TD] [TD]245376[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 15:49:56[/TD] [TD]267813[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 15:49:56[/TD] [TD]274821[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 15:49:56[/TD] [TD]373693[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 15:49:56[/TD] [TD]374699[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS ended[/TD] [/TR] [TR] [TD]2017-02-01 15:49:56[/TD] [TD]656961[/TD] [TD]10036[/TD] [TD]debug [/TD] [TD]EXE19000649 [v0.1]: Received last edit timestamp: 1485960422[/TD] [/TR] [TR] [TD]2017-02-01 15:49:56[/TD] [TD]657676[/TD] [TD]10036[/TD] [TD]debug [/TD] [TD]EXE19000649 [v0.1]: Last Edit Time : 1485960422[/TD] [/TR] [TR] [TD]2017-02-01 15:49:56[/TD] [TD]658320[/TD] [TD]10036[/TD] [TD]debug [/TD] [TD]EXE19000649 [v0.1]: Last Update Time: 1485960222[/TD] [/TR] [TR] [TD]2017-02-01 15:49:57[/TD] [TD]203782[/TD] [TD]10036[/TD] [TD]debug [/TD] [TD]EXE19000649 [v0.1]: Installed LBS: ["12000000","12000001","12000002","12000003","12000004","12000005","12000008","12000010","12000011","12000012","12000013","12000014","12000015","12000100","13000011","13000012","13000013","13000014","13000020","13000021","13000022","13000023","13000026","13000030","13000031","13000039","13000120","14000020","14000021","14000022","14000023","14000024","14000025","14000028","14000029","14000100","15000020","15000032","15000033","15000034","15000040","15000041","15000042","15000043","15000044","15000045","15000046","15000050","15000051","15000052","15000053","15000069","15000070","15000071","15000100","15000110","16000001","16000100","16000101","16000109","16000110","16000111","16000112","16000113","16000114","16000115","16000116","16000117","16000130","17000001","17000002","17000200","17000210","17000220","17000221","17000225","18000001","18000003","18000005","18000010","18000020","18000060","18000061","18000062","18000063","18000100","19000001","19000002","19000003","19000004","19000005","19000006","19000007","19000008","19000009","19000042","19000070","19000071","19000303","19000304","19000649","19000963","19000964","19900001","19900011"][/TD] [/TR] [TR] [TD]2017-02-01 15:49:57[/TD] [TD]204097[/TD] [TD]10036[/TD] [TD]debug [/TD] [TD]EXE19000649 [v0.1]: Used LBS: ["12000010","12000011","12000012","12000015","13000011","13000012","13000013","13000014","13000030","13000031","14000020","14000021","14000023","14000024","14000025","15000040","16000117","17000210","19000001","19000005","19000006","19000007","19000008","19000042","19000070","19000071","19000303","19000304","19000649","19000963"][/TD] [/TR] [TR] [TD]2017-02-01 15:49:57[/TD] [TD]397927[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS started[/TD] [/TR] [TR] [TD]2017-02-01 15:49:57[/TD] [TD]399148[/TD] [TD]12683[/TD] [TD]debug [/TD] [TD]LBS19000649 [v0.1]: LBS ended[/TD] [/TR] [/TABLE]
Hallo André,
der Telegram Contact hat die Version 0.7
Der Edomi Notification LBS, Ausgang 4 (Telegram) ist mit einer Ausgangsbox (ungleich 0) verbunden und schreib in das iKO in das auch andere Meldungen geschrieben werden und ankommen …
Dieses Verhalten hatte ich vor- und nachdem ich Edomi neu installiert habe ...
Wenn ich noch mal so richtig nachdenke, könnte das auch mit einer defekten Datenbank auf dem damaligen System zu tun gehabt haben....
N'abend miteinander
So habe ich das auch: Eine Logikseite, welche für das Versenden der Telegram-Meldungen da ist und via iKO gefüttert wird. In dieses iKO schreiben alle möglichen anderen Ausgangsboxen anderer Logikseiten. Das funktioniert ohne Probleme, sowohl mit meinen eigenen Statusmeldungen als auch den LBS-Update-Meldungen des Forums.Zitat von jonofe Beitrag anzeigenAllerdings funktioniert es bei mir und vermutlich bei anderen auch per iKO problemlos.
Wenn sich wirklich ein iKO anders verhält als eine direkte Verbindung im Logikeditor, dann wäre unterschiedliches Verhalten für mich ein Bug in EDOMI.
Christian wird uns bestimmt diesbezüglich bestimmt mehr Infos geben können.
Vorstellbar ist das schon, zumindest in meiner kleinen Welt.
Wenn ich das richtig im Kopf habe, werden gewisse Sonderzeichen aus den IKO entfernt. Inwieweit das dann Auswirkungen auf das senden haben kann, weis ich jetzt nicht.
Das sieht okay aus.
Kann es sein, dass du nicht den aktuellen Telegram-Contact LBS einsetzt. Das würde nämlich das Verhalten erklären. Und du müsstest eigentlich Fehler in Logs sehen.
Das es per iKO Verbindung funktioniert und per direkter Verbindung nicht, das kann ich mir nur schwer vorstellen.
Hallo André,
folgendes sehe ich heute:
Code:<code>\xF0\x9F\x86\x95 - NEUER LBS</code>\n<code>===============</code> <code>ID : </code><b>19000747</b> <code>Name : </code><b>Dezimalzeit</b> <code>Kategorie : </code><b>Zeit-Funktionen</b> <code>Autor : </code><b>Martin Ziegler (Brick)</b> <code>Version : </code><b>0.1</b> <code>Timestamp : </code><b>2017-02-01 15:47:02</b> <code>Link : </code><a href="https://service.knx-user-forum.de/?comm=download&id=19000747">LBS19000747</a>
Siehst du denn den Text am Input des Telegramm contact LBS?
Ich habe den LBS eh auf gleicher Seite, aber eben nur über iKO da ich zahlreiche Ausgangsboxen habe die dieser iKO die Werte (Meldungen) zuweisen ...
Hatte ich auch das Problem, bis ich den Update Baustein auf die selbe Logikseite gepackt habe, und direkt "verdrahtet" habe. Ich hab das aber dann nicht mehr nachverfolgt.
