first of all, IDs must be unique:
https://github.com/fluppie/Temperatu...device.xml#L74
In this line 15 and so on...
Same here
https://github.com/fluppie/Temperatu...config.xml#L73
and other IDs
This will not work:
https://github.com/fluppie/Temperatu...ter/loop.h#L98
I hope you have pressure more then 900
values above 900 is a special error handling in HTU21D library (like, if lib retuerns 900, there is something went wrong).
you can not use this values with BME680...
Same here
and other IDs
This will not work:
