Guten Morgen,
Danke! Es lag an der dll. Ins Verzeichnis mit der update.exe rein, dann hats sofort geklappt.
SynOhrUpdate 1.080 2014-01-14
Fixes
+ output value of common actuator for heating and cooling
+ if no GA for date is sent, a change of the month is not properly calculated
+ autocheck of sensor signals for humidity and temperature
SynOhrUpdate 1.080 2016-04-21
Fixes
+ version number set
+ needs SprachSchatz >2.093
+ level limit can be set
+ level limit can be enabled and disabled
+ output gain can be set
+ not activating touch sensors during DSP reset
