Zitat von udo1toni
# configuration for knxd.service #KNXD_OPTS="-e 0.0.1 -E 0.0.2:8 -u /tmp/eib -b ip:" KNXD_OPTS="-t 1023 -e 0.0.1 -E 0.0.2:8 -u /tmp/eib -t 1023 -b usb:" #KNXD_OPTS="-t 1023 -e 192.168.178.239 -E 192.168.178.240:8 -u /tmp/eib -D -T -R -S -t 1023 -b usb:" # The default options are "-u /tmp/eib -b ip:" # which tell knxd to route between all of # /tmp/eib (legacy socket (-u)) # multicast client (-b ip:). # knxd's own bus address is 0.0.1; it will assign 0.0.2?^`?0.0.9 to clients. # The knxd.socket file also tells knxd to listen to # /run/eib (socket activation via systemd) # TCP port 6720 (socket activation via systemd) # You *need* the -e option. Clients cannot connect without "-E". # You can read knxd's logs with # $ journalctl -u knxd --since "10 min ago" # (or whatever). See the manpage for details. # You need to be a member of the "adm" group. # Add "-f9 -t1023" to the beginning of the command line for extensive logging. # *** DO NOT use "-u" / "-u /run/knx" or "-i" / "-i 6720" here. # Systemd already does that on behalf of knxd, via 'knx.socket'. # *** DO NOT use both "-RS" and "-b ip:" (unless you specify a # different multicast address on one of them). You'd create a loop. # If you have KNX hardware on a serial port or USB, add the appropriate # "-b TYPE:?^`?" option. In this case, you probably want to set up a multicast # server, not a client (i.e. use "-D -T -R -S", not "-b ip:"). # DO NOT use both. # # If your KNX hardware is a KNX/IP gateway that doesn't do multicast, # use "-b ipt:192.168.1.2" (or its DNS name) to talk to it. # # KNX MUST NOT have more than one path between any two devices. Thus, # you need to make sure that the KNX/IP gateway does not route multicast # before you use both "-S" and "-b ipt:". # The default bus address of knxd is 0.0.1. If that's in use in your KNX # network (or if you run more than one knxd on your network), set a # different address, for example "-e 7.0.99". # You should have a block of free addresses on your KNX bus which knxd can # assign to clients: "-E 7.0.100:28" will use 7.0.100 through 7.0.127. # If no such range is given, or if it's full, knxd uses its own address. # That mostly works, but separate addresses are much better. # different multicast address on one of them). You'd create a loop. # If you have KNX hardware on a serial port or USB, add the appropriate # "-b TYPE:?^`?" option. In this case, you probably want to set up a multicast # server, not a client (i.e. use "-D -T -R -S", not "-b ip:"). # DO NOT use both. # # If your KNX hardware is a KNX/IP gateway that doesn't do multicast, # use "-b ipt:192.168.1.2" (or its DNS name) to talk to it. # # KNX MUST NOT have more than one path between any two devices. Thus, # you need to make sure that the KNX/IP gateway does not route multicast # before you use both "-S" and "-b ipt:". # The default bus address of knxd is 0.0.1. If that's in use in your KNX # network (or if you run more than one knxd on your network), set a # different address, for example "-e 7.0.99". # You should have a block of free addresses on your KNX bus which knxd can # assign to clients: "-E 7.0.100:28" will use 7.0.100 through 7.0.127. # If no such range is given, or if it's full, knxd uses its own address. # That mostly works, but separate addresses are much better. # Run `knxd --help` to get a complete list of available options and drivers. ## DO NOT use the following options: ## -i -- /lib/systemd/system/knxd.socket does this for us ## -u /run/knx -- likewise ## -d -- /lib/systemd/system/knxd.service expects knxd to run in the foreground ## -p PIDFILE -- please use systemctl to control knxd ############################################################################### # This file is ignored when NOT using systemd: edit /etc/default/knxd instead # ###############################################################################
# KNX gateway IP address # (optional, if serialPort or connection type 'ROUTER' is specified) #ip=224.00.23.12 ip=127.0.0.1 # Local KNX Binding bus address. # Use it, when two or more openHAB Instances are connected to the same KNX bus. # (optional, defaults to 0.0.0) #busaddr=192.168.178.23 #busaddr=1.1.34 # Ignore local KNX Events, prevents internal events coming from # 'openHAB event bus' a second time to be sent back to the 'openHAB event bus'. # Note: To send back events second time is a Bug, but for backward compatibility, the behavior is not changed. # For new installations, its recommend to set "ignorelocalevents=true" # (optional, defaults to false) #ignorelocalevents= # KNX IP connection type. Could be either TUNNEL or ROUTER (optional, defaults to TUNNEL) # Note: If you cannot get the ROUTER mode working (even if it claims it is connected), # use TUNNEL mode instead with setting both the ip of the KNX gateway and the localIp. #type=ROUTER type=TUNNEL # KNX gateway port (optional, defaults to 3671) # Note: If you use eibd, setting to 6720 port=3671 # Local endpoint to specify the multicast interface, no port is used (optional) #localIp=192.168.178.23 # Serial port of FT1.2 KNX interface (ignored, if ip is specified) # Valid values are e.g. COM1 for Windows and /dev/ttyS0 or /dev/ttyUSB0 for Linux #serialPort=/dev/ttyUSB0 # Pause in milliseconds between two read requests on the KNX bus during # initialization (optional, defaults to 50) #pause= # Timeout in milliseconds to wait for a response from the KNX bus (optional, # defaults to 10000) #timeout # Number of read retries while initialization items from the KNX bus (optional, # defaults to 3) #readRetries # Seconds between connect retries when KNX link has been lost # 0 means never retry, it will only reconnect on next write or read request # Note: without periodic retries all events will be lost up to the next read/write
