Problem gefunden. Es lag an der Installation.
-> das Binding über PaperUI : Extensions -> MISC -> Hue Emulation installiert und schon gehts ...
/******************************************************* #########################Wohnzimmer##################### *******************************************************/ Switch RoteLampe_Echo "Rote Lampe" ["Lighting"] Switch Stehlampe_Echo "Stehlampe" ["Lighting"] Switch Vitrine_Echo "Vitrine" ["Lighting"]
import org.openhab.core.library.types.*
import org.openhab.model.script.actions.*
Rotelampe
rule "Rotelampe"
when
Item RoteLampe_Echo received update
then
if (RoteLampe_Echo.state == ON){
sendCommand(SteckdWZ1,ON)
else if (RoteLampe_Echo.state == OFF)
sendCommand(SteckdWZ1,OFF)
//sendCommand(Switch1,OFF)
logInfo("rules", "Echo rule 1 triggered")
end
Vitrine
rule "Vitrine"
when
Item Vitrine_Echo received update
then
if (Vitrine_Echo.state == ON){
sendCommand(SteckdWZ3,ON)
sendCommand(Switch2,ON)
else if (Vitrine_Echo.state == OFF)
sendCommand(SteckdWZ3,OFF)
sendCommand(Switch2,OFF)
//logInfo("rules", "Echo rule 2 triggered")
end
Stehlampe
rule "Stehlampe"
when
Item Stehlampe_Echo received update
then
if (Stehlampe_Echo.state == ON){
sendCommand(SteckdWZ2,ON)
sendCommand(Switch1,ON)
else if (Stehlampe_Echo.state == OFF)
sendCommand(SteckdWZ2,OFF)
end
