2024-04-14 19:59:27 NOTICE lib.metadata Item 'EG.Raum3.AlexaRadio.Info.player_info', attribute 'volume': Attribute is undefined and has value 'alexa_cmd_01:True:Echo Bad:VolumeSet:#Alexas.Echo Bad.player_info.volume/#' (defined in home.yaml) 2024-04-14 19:59:27 NOTICE lib.metadata Item 'EG.Raum3.AlexaRadio.Info.player_info', attribute 'play': Attribute is undefined and has value 'alexa_cmd_01:True:Echo Bad:Play:nullalexa_cmd_02:False:Echo Bad:Pause:null' (defined in home.yaml) 2024-04-14 19:59:27 NOTICE lib.metadata Item 'EG.Raum3.AlexaRadio.Info.player_info', attribute 'mute': Attribute is undefined and has value 'alexa_cmd_01:True:Echo Bad:Mute:0alexa_cmd_02:False:Echo Bad:VolumeSet:20' (defined in home.yaml) 2024-04-14 19:59:27 NOTICE lib.metadata Item 'EG.Raum3.AlexaRadio.Info.player_info', attribute 'station_1': Attribute is undefined and has value 'alexa_cmd_01:True:Echo Bad:StartTuneInStation:s96141' (defined in home.yaml) 2024-04-14 19:59:27 NOTICE lib.metadata Item 'EG.Raum3.AlexaRadio.Info.player_info', attribute 'station_2': Attribute is undefined and has value 'alexa_cmd_01:True:Echo Bad:StartTuneInStation:s1561' (defined in home.yaml) 2024-04-14 19:59:27 NOTICE lib.metadata Item 'EG.Raum3.AlexaRadio.Info.player_info', attribute 'station_3': Attribute is undefined and has value 'alexa_cmd_01:True:Echo Bad:StartTuneInStation:s24896' (defined in home.yaml) 2024-04-14 19:59:27 NOTICE lib.metadata Item 'EG.Raum3.AlexaRadio.Info.player_info', attribute 'station_4': Attribute is undefined and has value 'alexa_cmd_01:True:Echo Bad:StartTuneInStation:s294232' (defined in home.yaml)
Grüße, Marc
