Zitat von Msinn
Für mich passt die Lösung.
{{ ovbasic.stateswitch ('hwr_light', 'haus.kg.hobbyraum.lampe.schalten', 'micro', ['1', '0'],['light_light_dim_100.svg', 'light_light_dim_00.svg'], '', ['icon1', 'icon0'], '', '', '', '', 'Hobbyraum: Deckenleuchte', '29%', '79%') }}
smartvisu:
plugin_name: smartvisu
smartvisu_dir: /var/www/html/smartvisu
generate_pages: True
# overwrite_templates: Yes
visu_style: std
default_acl: rw
handle_widgets: True
# list_deprecated_warnings: False
haus:
kg:
hobbyraum:
### -------Lichter------- ###
lampe:
schalten:
type: bool
knx_dpt: 1
knx_send: 3/0/8
knx_init: 3/0/8
visu_acl: rw
websocket:
module_name: websocket
ip: 192.168.1.134
port: 2424
# tls_port: 2425
# use_tls: True
# tls_cert: shng.cer
# tls_key: shng.key
2024-02-23 09:31:15 ERROR plugins.smartvisu get_data_html exception: Object of type datetime is not JSON serializable
2024-02-23 09:31:17 ERROR plugins.smartvisu {'items': {'env.core.version': {'type': 'str', 'value': 'v1.10.0-master (manual)', 'last_update': '23.02.2024 09:30:22', 'last_change': '23.02.2024 09:30:22'},.........
%YAML 1.1
navigation:
room:
- name: Keller
sv_nav_aside2: "{{ basic.symbol('', 'keller.leuchten', '', 'light_light.svg') }}"
img: control_building_s_kg.svg
- name: EG
separator: True
- name: Eingang
img: fts_door.svg
sv_nav_aside: "{{ basic.print('', 'eg.eingang.heizung.temperatur.ist', '°') }}"
sv_nav_aside2: "{{ basic.symbol('', 'eg.e.leuchten', '', 'light_light.svg') }}"
- name: Küche
img: scene_cooking.svg
sv_nav_aside: "{{ basic.print('', 'eg.kueche.heizung.temperatur.ist', '°') }}"
sv_nav_aside2: "{{ basic.symbol('', 'eg.kueche.leuchten', '', 'light_light.svg') }}"
category:
- name: Beleuchtung
sv_page: cat_overview
sv_overview: leuchte
img: light_light.svg
- name: Heizung
sv_page: overview
sv_overview: heizung
img: sani_heating.svg
%YAML 1.1
keller:
sv_page: room
sv_img: control_building_s_kg.svg
flur:
leuchten:
wand:
type: bool
knx_dpt: 1
knx_send: 1/0/11
knx_listen: 1/0/111
knx_init: 1/0/111
sv_widget: "{{ basic.stateswitch('','keller.flur.leuchten.wand','icon',[0,1],['light_light.svg','light_light.svg']) }} Flur"
sv_item_type: leuchte
treppe_eg:
type: bool
knx_dpt: 1
knx_send: 1/0/12
knx_listen: 1/0/112
knx_init: 1/0/112
sv_widget: "{{ basic.stateswitch('','keller.flur.leuchten.treppe_eg','icon',[0,1],['light_stairs.svg','light_stairs.svg']) }} Treppe"
eg:
wohnzimmer:
sv_page: room
sv_img: scene_dinner.svg
sv_nav_aside: "{{ basic.print('eg.west.ist', 'eg.wohnzimmer.heizung.temperatur.ist', '°') }}"
sv_nav_aside2: "{{ basic.symbol('eg.west.licht', 'eg.wohnzimmer.leuchten', '', 'light_light.svg') }}"
heizung:
sv_widget: "{{ device.rtr('','Heizung','eg.wohnzimmer.heizung.temperatur.ist','eg.wohnzimmer.heizung.temperatur.soll') }}"
sv_item_type: heizung
temperatur:
soll:
type: num
knx_dpt: 9
knx_send: 3/1/11
knx_listen: 3/1/11
knx_init: 3/1/11
cache: On
ist:
type: num
knx_dpt: 9
knx_listen: 3/1/12
knx_init: 3/1/12
database: yes
