### WARNING plugins.denon trying to send command zone1.control.power with value True, but plugin is suspended.
2024-06-09 16:42:19 WARNING plugins.denon command zone1.control.input with value CD produced error on converting value, aborting. Error was: Lookup of value cd in table INPUT failed, entry not found.
Unbedingt develop-Version nutzen, bitte.
2018-05-13 14:47:01 DEBUG Main 192.168.177.122:59883 sent '{"cmd":"item","id":"Haustechnik.Multimedia.denon.main.Input","val":"SIBT"}'
2018-05-13 14:47:01 DEBUG Main Item Haustechnik.Multimedia.denon.main.Input = SIBT via Visu 192.168.177.122:59883 None
2018-05-13 14:47:03 DEBUG denon Item Haustechnik.Multimedia.denon.main.Input = BT via DENON None None
2018-05-13 14:47:03 DEBUG denon Item Haustechnik.Multimedia.denon.zone2.Input = BT via DENON None None
<td width=10%>{{ basic.switch('Haustechnik.Multimedia.denon.input', 'Haustechnik.Multimedia.denon.main.Input', 'it_server.svg', 'measure_battery_0.svg', 'SIBT' , 'SINET') }}</td>
2018-05-13 14:42:07 DEBUG Main 192.168.177.122:59883 sent '{"cmd":"item","id":"Haustechnik.Multimedia.denon.main.Input","val":"SIBT"}'
2018-05-13 14:42:07 DEBUG Main Item Haustechnik.Multimedia.denon.main.Input = SIBT via Visu 192.168.177.122:59883 None
2018-05-13 14:42:09 DEBUG denon Item Haustechnik.Multimedia.denon.main.Input = NET via DENON None None
2018-05-13 14:42:19 DEBUG denon Item Haustechnik.Multimedia.denon.main.Input = BT via DENON None None
2018-05-13 14:42:20 DEBUG denon Item Haustechnik.Multimedia.denon.zone2.Input = BT via DENON None None
