Geändert!
./send 10101 1 1
2016-03-04 14:38:59,372 INFO steckdose Funksteckdosenlogik gestartet -- funksteckdosen.py:<module>:2 2016-03-04 14:38:59,962 INFO steckdose ['sending systemCode[10101] unitCode[1] command[1]\n'] -- funksteckdosen.py:<module>:10
[Funksteckdosen] [[System1]] name = Funksteckdosen [[[TasteA]]] type = bool name = Steckdose1 visu_acl = rw systemcode = 11111 geraetecode = 1
int main(int argc, char *argv[]) { /* output PIN is hardcoded for testing purposes see https://projects.drogon.net/raspberry-pi/wiringpi/pins/ for pin mapping of the raspberry pi GPIO connector */ int PIN = 0; char* systemCode = argv[1]; int unitCode = atoi(argv[2]); int command = atoi(argv[3]); if (wiringPiSetup () == -1) return 1; printf("sending systemCode[%s] unitCode[%i] command[%i]\n", systemCode, unitCode, command); RCSwitch mySwitch = RCSwitch(); mySwitch.enableTransmit(PIN);
sudo chown root:root /usr/smarthome/rcswitch-pi/send
sudo chmod u+s /usr/smarthome/rcswitch-pi/send
#!/bin/sh echo "17" > /sys/class/gpio/export echo "out" > /sys/class/gpio/gpio17/direction chmod 666 /sys/class/gpio/gpio17/value chmod 666 /sys/class/gpio/gpio17/direction
[Funksteckdosen] [[System1]] [[[TasteA]]] type = bool name = 1A visu_acl = rw knx_dpt = 1 sqlite = yes sim = track systemcode = 10000 geraetecode = 1 knx_send = 10/0/0 knx_cache = 10/0/0 [[[[uzsu]]]] type = dict uzsu_item = Funksteckdosen.System1.TasteA cache = True visu_acl = rw [[[TasteB]]] type = bool name = 1B visu_acl = rw knx_dpt = 1 sqlite = yes sim = track systemcode = 10000 geraetecode = 2 knx_send = 10/0/1 knx_cache = 10/0/1 [[[[uzsu]]]] type = dict uzsu_item = Funksteckdosen.System1.TasteB cache = True visu_acl = rw [[[TasteC]]] name = 1C type = bool visu_acl = rw knx_dpt = 1 sqlite = yes sim = track systemcode = 10000 geraetecode = 3 knx_send = 10/0/2 knx_cache = 10/0/2 [[[[uzsu]]]] type = dict uzsu_item = Funksteckdosen.System1.TasteC cache = True visu_acl = rw
#!/usr/bin/env python logger.info("Steckdosenlogik gestartet") import os if trigger['value'] is not None: source_item = sh.return_item(trigger['source']) output = os.popen("/usr/smarthome/rcswitch-pi/send "+ source_item.conf['systemcode'] +" "+ source_item.conf['geraetecode'] +" "+ str(int(trigger['value']== True ))).readlines() logger.info(output)
[hello] filename = hello.py crontab = init [dummy] filename = dummy_series.py cycle = 300 [steckdose] filename = steckdose.py watch_item = Funksteckdosen.System1.TasteA | Funksteckdosen.System1.TasteB | Funksteckdosen.System1.TasteC
/** * ----------------------------------------------------------------------------- * @package smartVISU * @author Martin Gleiß * @copyright 2012 * @license GPL [http://www.gnu.de] * ----------------------------------------------------------------------------- */ {% import "widget_uzsu.html" as uzsu %} {% block content %} <div class="block"> <div class="set-1" data-role="collapsible-set" data-theme="c" data-content-theme="a" data-mini="true"> <div data-role="collapsible" data-collapsed="false"> <h3>Funksteckdosen</h3> Taste A{{ basic.switch ('Funk1A' , 'Funksteckdosen.System1.TasteA' , icon1~'it_remote.png' , icon0~'it_remote.png' ) }}       {{ uzsu.uzsu_icon ('Funk_1A' , 'Funksteckdosen.System1.TasteA.uzsu', 'Schaltuhr Funksteckdose 1A', '0', '', '', 'bool', ['ein', 'aus']) }}<BR> Taste B{{ basic.switch ('Funk1B' , 'Funksteckdosen.System1.TasteB' , icon1~'it_remote.png' , icon0~'it_remote.png' ) }}       {{ uzsu.uzsu_icon ('Funk_1B' , 'Funksteckdosen.System1.TasteB.uzsu', 'Schaltuhr Funksteckdose 1B', '0', '', '', 'bool', ['ein', 'aus']) }}<BR> Taste C{{ basic.switch ('Funk1C' , 'Funksteckdosen.System1.TasteC' , icon1~'it_remote.png' , icon0~'it_remote.png' ) }}       {{ uzsu.uzsu_icon ('Funk_1C' , 'Funksteckdosen.System1.TasteC.uzsu', 'Schaltuhr Funksteckdose 1C', '0', '', '', 'bool', ['ein', 'aus']) }}<BR> </div> </div> </div> {% endblock %}
