Geändert!
./send 10101 1 1
2016-03-04 14:38:59,372 INFO steckdose Funksteckdosenlogik gestartet -- funksteckdosen.py:<module>:2 2016-03-04 14:38:59,962 INFO steckdose ['sending systemCode[10101] unitCode[1] command[1]\n'] -- funksteckdosen.py:<module>:10
[Funksteckdosen]
[[System1]]
name = Funksteckdosen
[[[TasteA]]]
type = bool
name = Steckdose1
visu_acl = rw
systemcode = 11111
geraetecode = 1
int main(int argc, char *argv[]) {
output PIN is hardcoded for testing purposes
see https://projects.drogon.net/raspberry-pi/wiringpi/pins/
for pin mapping of the raspberry pi GPIO connector
int PIN = 0;
char* systemCode = argv[1];
int unitCode = atoi(argv[2]);
int command = atoi(argv[3]);
if (wiringPiSetup () == -1) return 1;
printf("sending systemCode[%s] unitCode[%i] command[%i]\n", systemCode, unitCode, command);
RCSwitch mySwitch = RCSwitch();
mySwitch.enableTransmit(PIN);
sudo chown root:root /usr/smarthome/rcswitch-pi/send
sudo chmod u+s /usr/smarthome/rcswitch-pi/send
#!/bin/sh echo "17" > /sys/class/gpio/export echo "out" > /sys/class/gpio/gpio17/direction chmod 666 /sys/class/gpio/gpio17/value chmod 666 /sys/class/gpio/gpio17/direction
[Funksteckdosen]
[[System1]]
[[[TasteA]]]
type = bool
name = 1A
visu_acl = rw
knx_dpt = 1
sqlite = yes
sim = track
systemcode = 10000
geraetecode = 1
knx_send = 10/0/0
knx_cache = 10/0/0
[[[[uzsu]]]]
type = dict
uzsu_item = Funksteckdosen.System1.TasteA
cache = True
visu_acl = rw
[[[TasteB]]]
type = bool
name = 1B
visu_acl = rw
knx_dpt = 1
sqlite = yes
sim = track
systemcode = 10000
geraetecode = 2
knx_send = 10/0/1
knx_cache = 10/0/1
[[[[uzsu]]]]
type = dict
uzsu_item = Funksteckdosen.System1.TasteB
cache = True
visu_acl = rw
[[[TasteC]]]
name = 1C
type = bool
visu_acl = rw
knx_dpt = 1
sqlite = yes
sim = track
systemcode = 10000
geraetecode = 3
knx_send = 10/0/2
knx_cache = 10/0/2
[[[[uzsu]]]]
type = dict
uzsu_item = Funksteckdosen.System1.TasteC
cache = True
visu_acl = rw
#!/usr/bin/env python
logger.info("Steckdosenlogik gestartet")
import os
if trigger['value'] is not None:
source_item = sh.return_item(trigger['source'])
output = os.popen("/usr/smarthome/rcswitch-pi/send "+ source_item.conf['systemcode'] +" "+ source_item.conf['geraetecode'] +" "+ str(int(trigger['value']== True ))).readlines()
logger.info(output)
[hello]
filename = hello.py
crontab = init
[dummy]
filename = dummy_series.py
cycle = 300
[steckdose]
filename = steckdose.py
watch_item = Funksteckdosen.System1.TasteA | Funksteckdosen.System1.TasteB | Funksteckdosen.System1.TasteC
* @package smartVISU
* @author Martin Gleiß
* @copyright 2012
* @license GPL [http://www.gnu.de]
{% import "widget_uzsu.html" as uzsu %}
{% block content %}
<div class="block">
<div class="set-1" data-role="collapsible-set" data-theme="c" data-content-theme="a" data-mini="true">
<div data-role="collapsible" data-collapsed="false">
<h3>Funksteckdosen</h3>
Taste A{{ basic.switch ('Funk1A' , 'Funksteckdosen.System1.TasteA' , icon1~'it_remote.png' , icon0~'it_remote.png' ) }}
{{ uzsu.uzsu_icon ('Funk_1A' , 'Funksteckdosen.System1.TasteA.uzsu', 'Schaltuhr Funksteckdose 1A', '0', '', '', 'bool', ['ein', 'aus']) }}<BR>
Taste B{{ basic.switch ('Funk1B' , 'Funksteckdosen.System1.TasteB' , icon1~'it_remote.png' , icon0~'it_remote.png' ) }}
{{ uzsu.uzsu_icon ('Funk_1B' , 'Funksteckdosen.System1.TasteB.uzsu', 'Schaltuhr Funksteckdose 1B', '0', '', '', 'bool', ['ein', 'aus']) }}<BR>
Taste C{{ basic.switch ('Funk1C' , 'Funksteckdosen.System1.TasteC' , icon1~'it_remote.png' , icon0~'it_remote.png' ) }}
{{ uzsu.uzsu_icon ('Funk_1C' , 'Funksteckdosen.System1.TasteC.uzsu', 'Schaltuhr Funksteckdose 1C', '0', '', '', 'bool', ['ein', 'aus']) }}<BR>
</div>
</div>
</div>
{% endblock %}
