admin@smarthome:/usr/smarthome$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree... Done
Correcting dependencies... Done
The following extra packages will be installed:
owfs-common owfs-fuse owftpd owhttpd
The following NEW packages will be installed:
0 upgraded, 4 newly installed, 0 to remove and 82 not upgraded.
5 not fully installed or removed.
Need to get 0 B/101 kB of archives.
After this operation, 356 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 25007 files and directories currently installed.)
Unpacking owfs-common (from .../owfs-common_2.8p15-1_all.deb) ...
dpkg: error processing /var/cache/apt/archives/owfs-common_2.8p15-1_all.deb (--unpack):
trying to overwrite '/usr/share/man/man5/owfs.5.gz', which is also in package owserver 2.9p1-1.0
Unpacking owfs-fuse (from .../owfs-fuse_2.8p15-1_armhf.deb) ...
dpkg: error processing /var/cache/apt/archives/owfs-fuse_2.8p15-1_armhf.deb (--unpack):
trying to overwrite '/usr/share/man/man1/owfs.1.gz', which is also in package owserver 2.9p1-1.0
Unpacking owhttpd (from .../owhttpd_2.8p15-1_armhf.deb) ...
dpkg: error processing /var/cache/apt/archives/owhttpd_2.8p15-1_armhf.deb (--unpack):
trying to overwrite '/usr/share/man/man1/owhttpd.1.gz', which is also in package owserver 2.9p1-1.0
Unpacking owftpd (from .../owftpd_2.8p15-1_armhf.deb) ...
dpkg: error processing /var/cache/apt/archives/owftpd_2.8p15-1_armhf.deb (--unpack):
trying to overwrite '/usr/share/man/man1/owftpd.1.gz', which is also in package owserver 2.9p1-1.0
Processing triggers for man-db ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
admin@smarthome:/usr/smarthome$ sudo apt-get update
Hit http://archive.raspbian.org wheezy Release.gpg
Hit http://archive.raspbian.org wheezy/main armhf Packages
Hit http://archive.raspbian.org wheezy/contrib armhf Packages
Hit http://archive.raspbian.org wheezy/non-free armhf Packages
Ign http://archive.raspbian.org wheezy/contrib Translation-en_US
Ign http://archive.raspbian.org wheezy/contrib Translation-en_US.UTF-8
Ign http://archive.raspbian.org wheezy/main Translation-en_US
Ign http://archive.raspbian.org wheezy/main Translation-en_US.UTF-8
Ign http://archive.raspbian.org wheezy/non-free Translation-en_US
Ign http://archive.raspbian.org wheezy/non-free Translation-en_US.UTF-8
admin@smarthome:/usr/smarthome$ sudo apt-get upgrade
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
owfs : Depends: owfs-fuse (>= 2.8p15-1) but it is not installed
Depends: owhttpd (>= 2.8p15-1) but it is not installed
Depends: owftpd (>= 2.8p15-1) but it is not installed
E: Unmet dependencies. Try using -f.
admin@smarthome:/usr/smarthome$ date
Mon Mar 28 06:56:05 UTC 2016 (hängt 2 Stunden hinterher)
