1Wire will einfach nicht laufen - Pigator und DS18S20
    admin@smarthome:/usr/smarthome$ sudo apt-get -f install
    Reading package lists... Done
    Building dependency tree... Done
    Correcting dependencies... Done
    The following extra packages will be installed:
    owfs-common owfs-fuse owftpd owhttpd
    The following NEW packages will be installed:
    0 upgraded, 4 newly installed, 0 to remove and 82 not upgraded.
    5 not fully installed or removed.
    Need to get 0 B/101 kB of archives.
    After this operation, 356 kB of additional disk space will be used.
    Do you want to continue [Y/n]? y
    debconf: delaying package configuration, since apt-utils is not installed
    (Reading database ... 25007 files and directories currently installed.)
    Unpacking owfs-common (from .../owfs-common_2.8p15-1_all.deb) ...
    dpkg: error processing /var/cache/apt/archives/owfs-common_2.8p15-1_all.deb (--unpack):
    trying to overwrite '/usr/share/man/man5/owfs.5.gz', which is also in package owserver 2.9p1-1.0
    Unpacking owfs-fuse (from .../owfs-fuse_2.8p15-1_armhf.deb) ...
    dpkg: error processing /var/cache/apt/archives/owfs-fuse_2.8p15-1_armhf.deb (--unpack):
    trying to overwrite '/usr/share/man/man1/owfs.1.gz', which is also in package owserver 2.9p1-1.0
    Unpacking owhttpd (from .../owhttpd_2.8p15-1_armhf.deb) ...
    dpkg: error processing /var/cache/apt/archives/owhttpd_2.8p15-1_armhf.deb (--unpack):
    trying to overwrite '/usr/share/man/man1/owhttpd.1.gz', which is also in package owserver 2.9p1-1.0
    Unpacking owftpd (from .../owftpd_2.8p15-1_armhf.deb) ...
    dpkg: error processing /var/cache/apt/archives/owftpd_2.8p15-1_armhf.deb (--unpack):
    trying to overwrite '/usr/share/man/man1/owftpd.1.gz', which is also in package owserver 2.9p1-1.0
    Processing triggers for man-db ...
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    admin@smarthome:/usr/smarthome$ sudo apt-get update
    Hit http://archive.raspbian.org wheezy Release.gpg
    Hit http://archive.raspbian.org wheezy/main armhf Packages
    Hit http://archive.raspbian.org wheezy/contrib armhf Packages
    Hit http://archive.raspbian.org wheezy/non-free armhf Packages
    Ign http://archive.raspbian.org wheezy/contrib Translation-en_US
    Ign http://archive.raspbian.org wheezy/contrib Translation-en_US.UTF-8
    Ign http://archive.raspbian.org wheezy/main Translation-en_US
    Ign http://archive.raspbian.org wheezy/main Translation-en_US.UTF-8
    Ign http://archive.raspbian.org wheezy/non-free Translation-en_US
    Ign http://archive.raspbian.org wheezy/non-free Translation-en_US.UTF-8
    admin@smarthome:/usr/smarthome$ sudo apt-get upgrade
    You might want to run 'apt-get -f install' to correct these.
    The following packages have unmet dependencies:
    owfs : Depends: owfs-fuse (>= 2.8p15-1) but it is not installed
    Depends: owhttpd (>= 2.8p15-1) but it is not installed
    Depends: owftpd (>= 2.8p15-1) but it is not installed
    E: Unmet dependencies. Try using -f.
    admin@smarthome:/usr/smarthome$ date
    Mon Mar 28 06:56:05 UTC 2016 (hängt 2 Stunden hinterher)
      Versuch mal dies:
      sudo apt-get clean
      sudo apt-get autoremove
      sudo apt-get update
         [FONT=Menlo][SIZE=11px]admin@smarthome:/usr/smarthome$ sudo apt-get clean
         [/SIZE][/FONT]
          [HR][/HR] [FONT=Menlo][SIZE=11px]admin@smarthome:/usr/smarthome$ sudo apt-get autoremove[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Reading package lists... Done[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Building dependency tree... Done[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]You might want to run 'apt-get -f install' to correct these.[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]The following packages have unmet dependencies:[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px] owfs : Depends: owfs-fuse (>= 2.8p15-1) but it is not installed[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]        Depends: owhttpd (>= 2.8p15-1) but it is not installed[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]        Depends: owftpd (>= 2.8p15-1) but it is not installed[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]E: Unmet dependencies. Try using -f.
         [/SIZE][/FONT]
          [HR][/HR] [FONT=Menlo][SIZE=11px]admin@smarthome:/usr/smarthome$ sudo apt-get update[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Get:1 http://archive.raspbian.org wheezy Release.gpg [490 B][/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Get:2 http://archive.raspbian.org wheezy Release [14.4 kB][/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Get:3 http://archive.raspbian.org wheezy/main armhf Packages [6,908 kB][/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Get:4 http://archive.raspbian.org wheezy/contrib armhf Packages [23.6 kB][/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Get:5 http://archive.raspbian.org wheezy/non-free armhf Packages [49.3 kB][/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Ign http://archive.raspbian.org wheezy/contrib Translation-en_US[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Ign http://archive.raspbian.org wheezy/contrib Translation-en                                         [/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Ign http://archive.raspbian.org wheezy/contrib Translation-en_US.UTF-8                                [/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Ign http://archive.raspbian.org wheezy/main Translation-en_US                                         [/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Ign http://archive.raspbian.org wheezy/main Translation-en                                            [/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Ign http://archive.raspbian.org wheezy/main Translation-en_US.UTF-8                                   [/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Ign http://archive.raspbian.org wheezy/non-free Translation-en_US                                     [/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Ign http://archive.raspbian.org wheezy/non-free Translation-en                                        [/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Ign http://archive.raspbian.org wheezy/non-free Translation-en_US.UTF-8                               [/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]Fetched 6,996 kB in 22s (309 kB/s)        [/SIZE][/FONT]
         [/SIZE][/FONT]
          [HR][/HR] [FONT=Menlo][SIZE=11px]admin@smarthome:/usr/smarthome$ sudo apt-get upgrade[/SIZE][/FONT]
          [FONT=Menlo][SIZE=11px]E: Unmet dependencies. Try using -f.[/SIZE][/FONT]
        Ich habe mir einen RPI 1 bestellt und versuche es damit noch einmal. Hoffentlicht klappt es damit!
          Du kannst auch ein frisches raspbian nehmen und die ganzen Pakete dort einfach installieren(knxd,sh.py, 1w, etc.). Wahrscheinlich wird es schneller sein als dieses ping pong hier bis dein Image sauber ist.
          Du hast zur Zeit mehrere Probleme:
          - Keine passenden Module zu deinem Kernel, daher läuft i2c nicht
          - Paketabhängigkeiten können nicht aufgelöst werden, bzw. nicht nachinstalliert werden.
          - wenn i2c nicht läuft geht auch 1-Wire nicht.
          Ziel wäre es rpi-update zum laufen zu bekommen.
          Versuch bitte noch folgendes:
          sudo apt-get -f install fuse libfuse2 owfs owfs-fuse owftpd curl libcurl3 owhttpd
          wenn die Befehle durchlaufen
          sudo rpi-update
            setzt du knxd oder eibd ein?
