Kann aber nicht sagen warum mich das Gefühl beschleicht
2022-04-14 18:36:43 ERROR lib.plugin Plugin 'fb1' exception during import of __init__.py: invalid syntax (<fstring>, line 1) Traceback (most recent call last): File "/usr/local/smarthome/lib/plugin.py", line 548, in __init__ exec("import {0}".format(classpath)) File "<string>", line 1, in <module> File "<fstring>", line 1 (functionbitma sk) ^ SyntaxError: invalid syntax
fb1: class_name: AVM class_path: plugins.avm username: xyz password: xyz host: 192.168.70.10 port: 49443 cycle: 300 ssl: true # use https or not verify: false # verify ssl certificate call_monitor: 'True' # call_monitor_incoming_filter: "... ## optional, don't set if you don't want to watch only one specific number with your call monitor" instance: fritzbox_1 # avm_identifier: fritzbox_1
