Da ist er ja :-)
Und nun warten wir auf den nächsten Ausfall und schauen wieder.
smarthome@FuxlSmarthome:~ $ sudo systemctl status smarthome -l
● smarthome.service - SmartHomeNG daemon
Loaded: loaded (/lib/systemd/system/smarthome.service; enabled)
Active: active (running) since Tue 2016-10-18 15:44:30 CEST; 2h 46min ago
Process: 575 ExecStart=/usr/bin/python3 /usr/local/smarthome/bin/smarthome.py (code=exited, status=0/SUCCESS)
Main PID: 650 (python3)
CGroup: /system.slice/smarthome.service
└─650 /usr/bin/python3 /usr/local/smarthome/bin/smarthome.py
Oct 18 15:44:30 FuxlSmarthome python3[575]: Daemon PID 650
Oct 18 15:44:30 FuxlSmarthome systemd[1]: smarthome.service: Supervising process 650 which is not our child. We'll most likely not notice when it exits.
Oct 18 15:44:30 FuxlSmarthome systemd[1]: Started SmartHomeNG daemon.
smarthome@FuxlSmarthome:~ $ sudo lsof -Pan -p 650 -i
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
python3 650 smarthome 16u IPv4 9570 0t0 TCP 192.168.0.38:8383 (LISTEN)
python3 650 smarthome 17u IPv4 11293 0t0 TCP 127.0.0.1:50684->127.0.0.1:6720 (ESTABLISHED)
python3 650 smarthome 18u IPv4 11296 0t0 TCP 192.168.0.38:2424 (LISTEN)
python3 650 smarthome 19u IPv4 11297 0t0 TCP 127.0.0.1:2323 (LISTEN)
python3 650 smarthome 20u IPv4 10499 0t0 TCP 192.168.0.38:56880->192.168.0.2:80 (ESTABLISHED)
python3 650 smarthome 21u IPv4 11298 0t0 TCP 192.168.0.38:56882->192.168.0.2:80 (ESTABLISHED)
python3 650 smarthome 22u IPv4 14254 0t0 TCP 192.168.0.38:38350->192.168.0.36:49443 (ESTABLISHED)
python3 650 smarthome 23u IPv4 12221 0t0 TCP 192.168.0.38:43968->192.168.0.10:49000 (ESTABLISHED)
python3 650 smarthome 24u IPv4 14517 0t0 TCP 192.168.0.38:2424->192.168.0.26:43308 (CLOSE_WAIT)
python3 650 smarthome 25u IPv4 14583 0t0 TCP 192.168.0.38:33076->192.168.0.46:49443 (ESTABLISHED)
[visu]
class_name = WebSocket
class_path = plugins.visu_websocket
ip = 192.168.0.38
port = 2424
# tls = no
wsproto = 4
# acl = rw
2016-10-18 17:57:00 INFO Scheduler Adding worker thread. Total: 9
smarthome@Fuxl-Home:~ $ sudo systemctl status smarthome -l
Active: active (running) since Fri 2016-10-21 06:32:31 UTC; 2 days ago
Process: 1312 ExecStart=/usr/bin/python3 /usr/local/smarthome/bin/smarthome.py (code=exited, status=0/SUCCESS)
Main PID: 1316 (python3)
└─1316 /usr/bin/python3 /usr/local/smarthome/bin/smarthome.py
Oct 21 06:32:31 Fuxl-Home python3[1312]: Daemon PID 1316
Oct 21 06:32:31 Fuxl-Home systemd[1]: smarthome.service: Supervising process 1316 which is not our child. We'll most likely not notice when it exits.
Oct 21 06:32:31 Fuxl-Home systemd[1]: Started SmartHomeNG daemon.
smarthome@Fuxl-Home:~ $ sudo lsof -Pan -p 1316 -i
python3 1316 smarthome 5u IPv4 97790 0t0 TCP 192.168.0.38:37720->192.168.0.36:49443 (ESTABLISHED)
python3 1316 smarthome 16u IPv4 12784 0t0 TCP 192.168.0.38:8383 (LISTEN)
python3 1316 smarthome 17u IPv4 11080 0t0 TCP 127.0.0.1:35516->127.0.0.1:6720 (ESTABLISHED)
python3 1316 smarthome 18u IPv4 11081 0t0 TCP 192.168.0.38:2424 (LISTEN)
python3 1316 smarthome 19u IPv4 11082 0t0 TCP 127.0.0.1:2323 (LISTEN)
python3 1316 smarthome 20u IPv4 97183 0t0 TCP 192.168.0.38:49220->192.168.0.10:49000 (ESTABLISHED)
python3 1316 smarthome 21u IPv4 11083 0t0 TCP 192.168.0.38:51030->192.168.0.2:80 (ESTABLISHED)
python3 1316 smarthome 22u IPv4 12802 0t0 TCP 192.168.0.38:51034->192.168.0.2:80 (CLOSE_WAIT)
python3 1316 smarthome 23u IPv4 97799 0t0 TCP 192.168.0.38:48818->192.168.0.46:49443 (ESTABLISHED)
smarthome@Fuxl-Home:~ $ sudo ps -aux | grep smarthome
smartho+ 660 4.7 3.5 240288 33344 ? Dl Oct24 73:21 /usr/bin/python3 /usr/local/smarthome/bin/smarthome.py
root 6956 0.2 0.5 11480 4936 ? Ss 17:16 0:00 sshd: smarthome [priv]
smartho+ 6965 0.0 0.3 11480 3464 ? S 17:16 0:00 sshd: smarthome@pts/1
smartho+ 7011 0.0 0.2 4280 2008 pts/1 S+ 17:18 0:00 grep --color=auto smarthome
smarthome@Fuxl-Home:~ $ sudo systemctl status smarthome.service
Active: active (running) since Mon 2016-10-24 15:17:15 UTC; 1 day 2h ago
Process: 582 ExecStart=/usr/bin/python3 /usr/local/smarthome/bin/smarthome.py (code=exited, status=0/SUCCESS)
Main PID: 660 (python3)
└─660 /usr/bin/python3 /usr/local/smarthome/bin/smarthome.py
Oct 24 15:17:15 Fuxl-Home python3[582]: Daemon PID 660
Oct 24 15:17:15 Fuxl-Home systemd[1]: smarthome.service: Supervising process 660 which is not our child. We'll most likely not... exits.
Oct 24 15:17:15 Fuxl-Home systemd[1]: Started SmartHomeNG daemon.
Hint: Some lines were ellipsized, use -l to show in full.
2016-10-25 17:00:00 INFO Scheduler Adding worker thread. Total: 10
