Hast du denn das Plugin aktiviert in smarthome.py ? Kannst du mal deine Daten hier als zip einfügen?
Gruß Manuel
Gruß Manuel
[TABLE] [TR] [TD]<script type="text/javascript" src="[URL="http://192.168.3.13/smartVISU/pages/bogotz/visu.js"]pages/bogotz/visu.js[/URL]"></script>[/TD] [/TR] [TR] [TD]<link rel="stylesheet" type="text/css" href="[URL="http://192.168.3.13/smartVISU/pages/bogotz/visu.css"]pages/bogotz/visu.css[/URL]" />[/TD] [TD] [/TD] [/TR] [/TABLE]
[Licht]
[[Kueche]]
type = num
visu_acl = rw
knx_dpt = 1
knx_send = 0/0/1
knx_listen = 0/1/1
[[[UZSU]]]
[S]name = Schaltuhr Kueche[/S] entfällt
type = [S]bool[/S] dict
uzsu_item = Licht.Kueche
cache = [S]True[/S] yes
visu_acl = rw
{% extends "rooms.html" %} {% block content %} {% import "widgets/widget_uzsu.html" as uzsu %} <div class="block"> <div class="set-2" data-role="collapsible-set" data-theme="c" data-content-theme="a" data-mini="true"> <div data-role="collapsible" data-collapsed="false"> <h3>Licht</h3> {{ uzsu.uzsu_icon('Kueche.time', 'Licht.Kueche.UZSU', 'Kueche Zeitschaltuhr', '', '0', '', '', 'bool' )}} UZSU </div> </div> </div> {% endblock %}
2018-06-24 07:32:35 INFO Main Initialized plugin 'sqlite_visu2_8' from from section 'sql'
2018-06-24 07:32:35 INFO Main Loading '/usr/local/smarthome/plugins/uzsu/plugin.yaml' to 'OrderedDict'
2018-06-24 07:32:35 INFO Main plugin 'uzsu': No parameter definitions found in metadata
2018-06-24 07:32:35 INFO Main Init UZSU
2018-06-24 07:32:35 INFO Main Initialized plugin 'uzsu' from from section 'uzsu'
2018-06-24 07:32:35 INFO Main Load of plugins finished
2018-06-24 07:32:35 INFO Main Start initialization of items
2018-06-24 07:32:35 INFO Main Loading '/usr/local/smarthome/lib/env/core.yaml' to 'OrderedDict'
2018-06-24 07:32:35 INFO Main Loading '/usr/local/smarthome/lib/env/location.yaml' to 'OrderedDict'
2018-06-24 07:32:35 INFO Main config.parse_itemsdir: skipping logic definition file = /usr/local/smarthome/lib/env/logic.yaml
2018-06-24 07:32:35 INFO Main Loading '/usr/local/smarthome/lib/env/system.yaml' to 'OrderedDict'
2018-06-24 07:32:36 INFO Main Items initialization finished, 110 items loaded
2018-06-24 07:32:36 INFO Main Start Logics
2018-06-24 07:32:36 INFO Main Loading '/usr/local/smarthome/lib/env/logic.yaml' to 'OrderedDict'
2018-06-24 07:32:36 INFO Main Loading '/usr/local/smarthome/etc/logic.yaml' to 'OrderedDict'
2018-06-24 07:32:36 INFO Main Start plugins
2018-06-24 07:32:36 INFO Main Start of plugins finished
[Dg] [[Treppenhaus]] [[[Licht]]] [[[[Decke]]]] [[[[[schalten]]]]] type = bool name = Licht_A visu_acl = rw knx_dpt = 1 sqlite = init cache = yes enforce_updates = true knx_send = 0/0/200 knx_cache = 0/0/201 [[[[[[Uzsu]]]]]] type = dict uzsu_item = Dg.Treppenhaus.Licht.Decke.schalten cache = yes visu_acl = rw
{{ device.uzsuicon('Treppenhaus', 'Dg.Treppenhaus.Licht.Decke.schalten.Uzsu', 'Zeitschaltuhr Treppenhaus', '', '', 'bool', ['Ein:on', 'Aus:off']) }}
