Video Stream to Gira TKS IP Gateway
    Was zeigt denn das log des Containers wenn du im Gira TKS auf „Vorschau“ drückst?
      Das sind die Logs... Habe den Container neugestartet:
      /etc/ffserver.conf:34: Setting default value for video bit rate tolerance = 100000. Use NoDefaults to disable it.
      /etc/ffserver.conf:34: Setting default value for video rate control equation = tex^qComp. Use NoDefaults to disable it.
      /etc/ffserver.conf:34: Setting default value for video max rate = 800000. Use NoDefaults to disable it.
      /etc/ffserver.conf:34: Setting default value for video buffer size = 800000. Use NoDefaults to disable it.
      Fri May 6 22:06:39 2022 [ffm @ 0x563ea7a8e7a0]Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
      /etc/ffserver.conf:44: Setting default value for video bit rate = 64000. Use NoDefaults to disable it.
      /etc/ffserver.conf:44: Setting default value for video bit rate tolerance = 32000. Use NoDefaults to disable it.
      /etc/ffserver.conf:44: Setting default value for video rate control equation = tex^qComp. Use NoDefaults to disable it.
      /etc/ffserver.conf:44: Setting default value for video max rate = 128000. Use NoDefaults to disable it.
      /etc/ffserver.conf:44: Setting default value for video buffer size = 128000. Use NoDefaults to disable it.
      Fri May 6 22:06:39 2022 FFserver started.
      Fri May 6 22:06:39 2022 Launch command line: /usr/bin/ffmpeg -i rtsp://192.168.33.1:7447/bxyzMM0rAJYZoGJq?enableSrtp http://127.0.0.1:8090/unifi.ffm
      Fri May 6 22:06:44 2022 127.0.0.1 - - [GET] "/unifi.ffm HTTP/1.1" 200 4175
      Fri May 6 22:10:12 2022 172.17.0.1 - - [TEARDOWN] "rtsp://192.168.33.10/s0 RTSP/1.0" 200 80
      Fri May 6 22:10:12 2022 172.17.0.1:9480 - - "PLAY s0/streamid=0 RTP/UDP"
      Fri May 6 22:12:11 2022 172.17.0.1 - - [TEARDOWN] "rtsp://192.168.33.10/s0 RTSP/1.0" 200 829
      Fri May 6 22:15:31 2022 172.17.0.1 - - [TEARDOWN] "rtsp://192.168.33.10/s0 RTSP/1.0" 200 80
      Fri May 6 22:15:31 2022 172.17.0.1:9428 - - "PLAY s0/streamid=0 RTP/UDP"
      Sieht eigentlich unauffällig aus oder?
        Zitat von TimmK Beitrag anzeigen
        Moin Kai,
        Komisch, Hier mal 2-3 Ansätze:
        Funktioniert der Video-Stream Abruf per VLC?
        Die html-Seite vom ffserver bwz log kann für das debug auch weiterhelfen....
        Routing/netze/firewall kann ausgeschlossen werden?
        Viel Erfolg
        Danke für die Tipps.
        1) Also der Aufruf in VLC klappt über den Browser nicht. Normalerweise wenn ich einen Stream lade über den Browser lädt er eine Datei herunter, die ich dann in VLC öffnen kann. Wenn ich hier aber im Browser "192.168.33.10:8090/s0" eingebe lädt er nur eine leere Datei herunter mit der VLC nichts anfangen kann.
        Öffne ich den Stream aus meiner Config ein "rtsp://192.168.33.1:7447/bxyzMMsdsaJYZoGJq?enableSrtp" direkt in VLC, öffnet sich nach einiger Zeit zwar das Abspielfenster jedoch kommt kein Bild. Wenn die folgenden Stream öffne "rtsp://192.168.33.1:7447/bxyzMMsdsaJYZoGJq" läuft alles ohne Probleme.
        2/3) Die Logs sehen für mich soweit in Ordnung aus und am Netzwerk dürfte es auch nicht liegen. Zumal ja der Screenshot funktioniert. Auch habe ich die gleichen Streams bei mir noch in IPSymcon (Heimautomation). Der Server steht im gleichen Netz wie der Docker-Server und dort werden die Videos korrekt gestreamt. Natürlich nicht über den Umweg ffserver, sondern direkt aus UnifiProtect.
        Anmerkung: Die HTML ffserver Seite bekomme ich leider nicht angezeigt.
          Hallo KingKahn,
          ich war das WE leider unterwegs...
          Tatsächlich sehen Deine LOGs für mich auch unauffällig aus.
          Ich hatte am Anfang auch ein paar Probleme und habe ffmpeg und ffserver seperat gestestet und gestartet. Ggf. ist der ffmpeg ok und der ffserver läuft nicht sauber... Gute Frage....
          Wenn ich mit der VLC-App pber den Pfad öffne, funktioniert es bei mir: rtsp://192.168.x.x/s0
          Hast Du das so getestet, das muss funktionierten, sonst bekommt das TKS-GW auch sicher kein Bild...
          Die Statussseite öffnet im Browser bei mir unter http://192.168.x.x:8090/stat.html
          hier werden zumindest Streams und Zugriffe angezeigt, funktioniert die bei Dir nicht? Irgendwas scheint mit dem ffserver nicht zu passen....
          Viel Erfolg
            Hi zusammen,
            ich habe es jetzt zumindest auf einem neu aufgesetzten Raspberry PI ans Laufen bekommen. :-) Danke schon mal für die Hilfe.
            TimmK: Die Links von der oben klappen auch. Auf der Sysnology NAS im Docker sieht auch alles super auf. Aber irgendwie muss dort netzwerktechnisch nicht passen.
            Ich wollte jetzt nochmal einen Container auf dem Raspberry PI installieren, da ich das schicker finde als die klassische Installation. Dort bekomme ich jedoch einen Fehler. Ich habe dazu im GitHub auch ein Issue aufgemacht. Falls ihr mal Zeit habt, wäre super danach zu schauen.
            Bin erstmal happy, dass es jetzt klappt :-)
            Danke,
            Kai
              Schönen guten Tag,
              ich habe es nun mit der Anleitung versucht.
              Als Ausgabe bekomme ich folgendes:
              welche Zeile beeinflusst Stream 0, ist das der Eingangsstream, oder der Ausgang?
              Zuletzt geändert von xerxes09; 27.08.2022, 08:49.
                Hi zusammen,
                ich habe das gleiche "Problem" wie xerxes09. Ich habe den Docker auf meiner Synology installiert und beim Starten bekomme ich immer die Fehlermeldung das der Docker-Container unerwartet gestoppt wurde. Die log-files sehen folgendermaßen aus:
                Ich habe an den Standardports 554 und 8090 nichts geändert....
                Wäre super wenn mir hier jemand Hilfestellung geben könnte.
                  Xienter das sieht was so aus als wäre bei dir das Config File kaputt...
                  Hast du das letzte Docker Image verwendet? Es gab ein Problem aber das wurde im Juli gefixt.
                  Sieht für mich bei dir nach dem selben Fehler aus
                  Zuletzt geändert von Geg0r; 28.09.2022, 18:57.
                    Zitat von xerxes09 Beitrag anzeigen
                    Schönen guten Tag,
                    Was nutzt du als Input?
                    Man kann nur sehen das der ffserver gleich wieder in die Knie geht.
                    Nutzt du das Docker Image oder die manuelle Installation?
                      wollte mich mal erkundigen, ob bei Euch noch alles funktioniert ?
                      Seit ca. 2 Wochen startet bei mir der Container gar nicht mehr.
                      -Ich bekomme immer den Fehler Docker Error Code 400
                      -bzw. "/usr/bin/docker-entrypoint.sh": permission denied: unknown
                      Habe jetzt mal versuche, alles zu löschen und auf dem bestehenden System den Container neu anzulegen. Leider alles ohne Erfolg...
                      Letzte Container Update liegt ungefähr im gleichen Zeitraum.(28.09)
                      Habe jetzt ein 3 Wochen altes Backup eingespielt (mit dem alten Container-Stand) und alles funktioniert. Sehr seltsam....
                      Kann es sein, dass am Container etwas nicht mehr passt? Ich blicke leider nicht so wirklich durch, was jetzt anders ist....
                      Habt ihr ein ähnliches Phänomen?
                      Danke und bis bald
                      Timm​
                        Oh man, ich bin einfach zu blöd um Docker bzw. Docker compose auf einem Raspi 4 oder Synology zum laufen zu bringen. Wäre jemand bereit mir unter die Arme zu greifen? Gern auch per TeamViewer...?
                        im Anhang beispielsweise die Fehlermeldung vom Raspi. Und bei der Synology wird mein Container immer nach start unverzüglich wieder gestoppt....
                          Zieht euch bitte nochmal das aktuelle Docker Image TimmK wir haben nochmal was neu gebaut.
                          Denke da hats beim Container bauen zerlegt...
                          Jokl deine Fehler ist irgendwie komisch...
                          Hast du auf einem leeren Raspi einfach docker und docker compose installiert?
                          Zum Beispiel so: hxxps://linuxhint.com/install_docker_raspberry_pi-2/
                          Du musst das inkl. dem Teil "docker compose" ausführen...
                          Und dann das compose file von github verwenden.
                          Zuletzt geändert von Geg0r; 17.10.2022, 19:01.
                            Hallo Geg0r ,
                            Vielen Dank für den schnellen Support! Jetzt funktioniert das Image wieder!
                            Klasse und bis bald!
                            TimmK
                              Und dann das compose file von github verwenden.[/QUOTE]
                              ich bin nach dieser Anleitung vorgegangen um Docker und im Anschluss Docker Compose zu installieren:
                              Docker & Docker-Compose auf dem RaspberryPi – BangerTECH​
                              Nach "Step 5", sudo pip3 install docker-compose, bringt er mir leider den oben gezeigten Fehler. Raspi oder NAS, wäre mega, wenn ich das Ding zum laufen bringen würde!!!
                              Dank vorab für eure Hilfe!
                                Hi Jokl hast du mal versucht den Befehlt der angezeigt wird auszuführen "sudo pip install --upgrade pip" und dann nochmal "sudo pip3 install docker-compose"
