Hello,
I am trying to build a HS Baustein for asking a colorNAME.
Input1: R (0-255)
Input2: G (0-255)
Input3: B (0-255)
Output: 14byte text
Using Python Pynche (See: http://svn.python.org/projects/pytho.../pynche/README )
Or Google: https://www.google.nl/search?espv=2&...71.fqEQu1YtKuE
Purpose is for example: A tastsensor to switch the light On/Off and with a button below you can < > walk through the colors. The colorname is then displayed at the TS3+ display, within the QC or on a InfoDisplay2.
I probably also need an "Input4: Trigger (1bit)"
Otherwise when you change colors (all 3 values are transmitted in serial and you get 3 output names, only the last one is valid)
Are any other people intrested or have any feedback/comments/ideas?
Input1: R (0-255)
Input2: G (0-255)
Input3: B (0-255)
Output: 14byte text
