HomeServer dead
    HS/FS HomeServer dead
    Hello,
    My HS doesn't reply to the ping.
    Reboot. No change (no beep, no LED on the front panel)
    Install a monitor and keyboard. Nothing on display
    Replace external power supply. No change.
    Replace external power supply, again. No change.
    Replace external power supply yet another. No change.
    Remove and re-plug all movable components. No change.
    I suspect the internal Power Supply board, namely the DC/DC converter but before, I would like to get another board.
    The HS is from 2004, quite an age, but I'd like to fix it.
    The internal Power Supply board is 16 x 5 cm, with some info:
    94V0 E248803
    www.morex.com.tw
    On the motherboard: EPIA-5000, but that doesn't give any clue.
    Anybody can help, with a part number, reference or where to buy ?
    Thank you
    The keyword for the search engine is „pico psu“ https://knx-user-forum.de/forum/öffe...plötzlich-tot
      Sorry to be a pain ... but I'm unable to locate the right spare part.
      Can you help me with a direct pointer, please ?
      Thanks
        This will work: https://www.amazon.de/PicoPSU-90-DC-...cm_rdp_product
          Is it this what you mean ?
          I've seen it, but .... No go
          I mean the internal Power Supply of a HS2 (small black) power supply
          The internal Power Supply board is 16 x 5 cm, written on the board
          www.morex.com.tw
            Oh i did not notice its a HS2 sorry! MatthiasS can cou help?
              It is the same for the black HS2. Get rid of that internal board and use a pico psu instead. A Pico Psu has the same functionality as the crappy Molex board. But much more efficient!
              This gallery has 1 photos.
              Zuletzt geändert von MatthiasS; 26.05.2018, 16:03.
