Hello,
My HS doesn't reply to the ping.
Reboot. No change (no beep, no LED on the front panel)
Install a monitor and keyboard. Nothing on display
Replace external power supply. No change.
Replace external power supply, again. No change.
Replace external power supply yet another. No change.
Remove and re-plug all movable components. No change.
I suspect the internal Power Supply board, namely the DC/DC converter but before, I would like to get another board.
The HS is from 2004, quite an age, but I'd like to fix it.
The internal Power Supply board is 16 x 5 cm, with some info:
94V0 E248803
www.morex.com.tw
On the motherboard: EPIA-5000, but that doesn't give any clue.
Anybody can help, with a part number, reference or where to buy ?
Thank you
94V0 E248803
www.morex.com.tw
Thank you
