GIRA (HS/FS) - DPT 11 to Text
    Hi everyone ,
    I'd like to convert a DPT 11 / EIS 4 ( Date .. but not Bus date ) to Text . I tried many logic ..but I could not find one who do what I need .
    Can someone help me ?
    Thank you
    http://service.knx-user-forum.de/?co...nload&id=12729 should do this
    Nils
    aktuelle Bausteine:
      Already tried ..but doesn't work
        then you probably made it wrong.
        if I understand it correct, you want to display a DPT 11 (EIS4) value from the KNX in the visu.
        1) create the KO with type 14Byte Text (NOT AS EIS4) and the correct group adress.
        2) connect that KO with A2 from the Logikbaustein
        3) (optional) change E4 to your disired output format
        4) add that KO to your Visu
        Nils
        aktuelle Bausteine:
          Yes .. I want to display the consumption reset date of a flow counter from ARCUS .
          To display this date I need to convert the DPT11 message to a texte 14byte .
          I connected the EIB object to the "logikbaustein 12729" and on the "A2" output port the HS internal object 14byte ... but.. nothing ..!
            you have to connect the EIB Object to A2 but change the type from EIS4 to 14Byte (no other internal objects).
            Dont connect anything to the inputs of the "Logikbaustein" just accept the defaults on E4 (in yellow)
            EDIT: you could also check the "beim starten abfragen" to read the initial value on startup
            Zuletzt geändert von NilsS; 12.12.2018, 08:57.
            Nils
            aktuelle Bausteine:
              ooookkk .. it works ! Thank you very much !
              But .. I have another question .. because I don't like this solution ... I mean .. all time I'll upload an EIB project after I modified something with ETS the DPT will come back to EIS4 .. so I'll have to fix manually the DPT ... do you think there is another solution ?
