Ist das mittlerweile schon möglich https-Seiten abzufragen ?
Webabfragen https
Hi Nils,
Nice to hear from you again https://knx-user-forum.de/images/icons/icon7.gif
OK, I'll have a lookZitat von NilsS Beitrag anzeigenyou can have a look in the prowl Logikbaustein.
I use it to monitor my own forum,Zitat von NilsS Beitrag anzeigenWhat do you need it for?
https://groups.google.com/forum/?hl=.../domotique-eib
and I'm kind of "forced" to use https.
Even if I issue a http command, Google forces the answer on https.
Although I don't fully understand the issue, because the XML reply is as before and my Webabfrage should run, but Debug says
PS: I'm still a happy user of the xxAPI, thanks again for that.(Gesamt: 202) (Work: 2) (Typ: Liste) (OK: 0)
HI,
Don't like it, but I'm quoting myself ...
According to a friend, running 4.1, it works. At least a Webabfrage is running with https.Zitat von Warichet Beitrag anzeigenDoes it work with newer release ?
I'm running 2.8 and seems not to work.
If this is true, it's a good reason to upgrade to 4.1 although I'm always scared to break the nice xxAPI with an upgrade.
Anyone running 4.1 and https ?
Anyone running 4.1 and the xxAPI ?
Thank you for your comments.
