KNX node for node-red
    Hello Max,
    would it be possible to integrate support for the Data Type 242.600 colour xyX?
    Thank you for your awesome work!
      Will take a look at.
        Thank you Tobias!!!!
          Hello Tobias,
          what make/model of knx device needing 242.600 are you using?
          I'm trying to figure out this datapoint, as it's unusual.
          Thanks,
            Hello Tobias
            already done by myself.
            V. 1.1.98 with datapoint 242.600 is out.
              Cool thank you very much!
              Sorry just saw your question. Just for completion, I want to use it with a Dali Gateway.
                Hello , I have a problem with the new update , I have all my knx lights linked in a flow to control them , after the update goes none of the lights to control over the dashboard. I have entered the Ip of the interface and all nodes are timed as connected, if I do something on the MDT button, the status changes, but when I switch in the dashboard nothing changes in the bus. So nothing is written. have you given me a tip what I need to change or what I have overlooked ? Thank you in advance
                  Hi Morpheus.
                  please tell me more about your setup. Do you have a KNX/IP interface or a KNX/IP router? Can you show me your config window and a screenshot of your flow?
                  The issue appears only after updating to new version? What version you had installed before?
                    Hello The Max
                    i have both , but at the moment i use the ip interface .
                    i dont know wich version i used before , can u tell me where i can see this ?
                        this config worked at the old version , now i see that the telegram is seen at the node , but if iuse the switch on the dashboard no reaction is send to the bus
                          Nowhere, you cannot.
                          If knx-ultimate is able to pick up the bus traffic, it should be able to send the messages to the bus as well.
                          The only thing i can suggest you, is to check if you're IP Interfaces has reached the maximum simultaneus connection limit allowed.
                          Many times, the IP interface doesn't free connection even after reboot of the interface itself. I can suggest you to check that and eventually to change the physical address of the configuration node (you find this option in the configuration node window).
                            But... what looks like the nodes status whenever you issue a command from the dashboard? (you can put an inject node and try directly from the flow, if it's more confortable to you).
                              I need to go now to buy the gifts for Christmas.
                              If you cannot solve that, try to restart node-red or try to follow this https://github.com/Supergiovane/node...Q-Troubleshoot and to do what i wrote in https://knx-user-forum.de/forum/öffe...11#post1583911
                              I'll check your messages in the evening, after i collected the gifts.
                                this happens
