KNX node for node-red
    i changed from ip interface to router with no success
    once again i see a reaction in the node whet i hit the mdt , but there is no reaction on the bus when i hit the switch on the dashboard .
    i dont have any clou about what happens
      now it works , the problem was the knx adress , i changed to router an set Network interface to auto after that it works.
      But i get the status failure "disabled due to circukare reference " when i bind in the node like this 1.PNG
      But it works an the status at the mdt changes also the right way.
      if i bind the node like this the status change is not send to the dashboard if i hit the mdt
      Do i need another node to send sthe status back to the dashboard ?
        if i do it like this it works with the mdt an the dashboard but i need more nodes ( but then without the failure )
          Hallo
          Ahhh, but it's very simpole. The circular protection kicks in!
          It prevents loops that can block node-red GUI.
          Enable the RBE filter for output messages, or follow this "CIRCULAR REFERENCE PROTECTION KICKS IN. WHAT THE HELL IS THAT?" in the FAQ page https://github.com/Supergiovane/node...Q-Troubleshoot
            So ergibt es ja auch mehr Sinn. Rückmeldeadresse auf Button, Button auf Schaltadresse
            Meine Konfog sieht auch so aus.
            This way it makes just more sense: Feedback adress to button, button to schwitching adress
            My config looks the same.
              Zitat von TheMax74 Beitrag anzeigen
              PS: feel free to try the hikvision-ultimate node as well.
              https://flows.nodered.org/node/node-red-contrib-hikvision-ultimate
              Awesome work Massimo!
              Thank you for this contribution.
              (The link has to be corrected to hikvision)
              Chris (https://proknx.com)
              wir haben ARAGON entwickelt, einen offline Sprachassistenten für KNX.
              Google, Amazon und Apple hätten das auch gekonnt. Aber sie verdienen eben besser an unseren persönlichen Daten...
                Fixed the link. Thank you!
                  Hi Massimo,
                  me again regarding the datapoint 242.600. It seams to me that the RBE filter is always catching messages, regardless if x y or brightness has changed. If the RBE option is deactivated, every message is passed trough, as expected.
                    Thank you for raising the issue. The Payload of 242.600 is an object instead of a straight value. It can be. I'll take a look.
                      A fix for that is out today with version 1.1.99.
                        Thank you!
                          24 December 2020, introducing TTS-Ultimate. https://flows.nodered.org/node/node-...b-tts-ultimate
                          Transforms the text in speech and hear it using Sonos player. Works with Sonos + Amazon, Google or your own voice.
                          Buon Natale!
                          image_105830.png​
                            Feliz Navidad to all
                            The Max74 do you have a clue how i can implement my Reolink Cams to the Node Red Dashboard , is there any node available for grabbing the stream from reolink cams ?
                            Thx in Advance
                              Hi Morpheus,
                              Nope. I develop only for gears i own and i own no Reolink and i don't know how to do it. If it supports ONVIF, you can use any of the ONVIF nodes to grab pictures. Go check it out!
                                TTS-Ultimate 1.0.5 is out with google translate voices, WITHOUT ANY CREDENTIAL NOR AUTHENTICATION NEEDED!
                                https://www.facebook.com/supergiovan...38607417507852
