KNX node for node-red
    Is it normal to have two highlighted rows in the datapoint selection?
    Are you sure to be picking up the right exported file?
      So, yes, I would say that I pick up the right exported file.
      But your first question is a good one: I do not know. For this device, this is given by default, for all KOs, including the ones not connected. I did not change anything. You can see it in the screenshot above. For other devices, this is clearly not the case.
      Should I try changing the selection?
        Yes, try and see what happens.
          Alright, thank you, will do tonight and will let you know
            At night i sleep and i cannot help you. See you tomorrow!
              That is of course alright :-) See you tomorrow!
                Well, testing was super quick ... it now works as designed. Changing the default multi-selection DPT to just the sub DPT was the trick. Thank you again for your help, TheMax74 !
                  Hi TheMax74
                  after updating to the latest version, the knxUltimate does not work any more and even stops all my flows. I get the following Error (translated from German):
                  The Flows were stopped because of missing Nodetypes:
                  knxUltimate-config
                  I had a working configuration (with imported GA-Export), but now, I don't even get to the configration, there is just a cryptic-number shown as the gateway...
                  Some days ago, I had to dismount my knx testboard, but before it was never a problem, when I had switched of my knx-installation, so I assume, that I have a different problem...
                    Hello
                    please install the old version.
                      npm install node-red-contrib-knx-ultimate@1.2.34
                        TheMax74
                        Thanks for the quick response... Unfortunately, that did not help.
                        I looks as if the config-node for knxUltimate has been corrupted. I see an "unkown" configuration node with the same number "cf1b6a4d.edff18" that is shown as gateway in the knx-nodes.
                        Any idea how this happened and how i could fix it?
                        Zuletzt geändert von martiko; 24.07.2021, 20:27.
                          Hi
                          Please upgrade as soon as you see v1.2.36. Is out now. It should fix all.
                            If you wish, you can send me your json flow file (maxsupergiovane@icloud.com) or paste it here.
                              now i See this error for knxUltimate in my Node palette:
                              • Error: Cannot find module 'crypto-js' (line:1)
                              I will wait until v1.2.36 is out, if the Problem should persist, I will sent you my json flow…
                                Yes, this will fix all your issues. Sorry for that, something wrong happened while updating the node via npm package.
