KNX node for node-red
    Hi stives
    i saw only now your msg. Will work on that.
      Hi Stives
      Done with node-red-contrib-knx-ultimate@1.4.15
      ​Out now.
        Thank you very much for this integration.
        We can see that at 5 second intervals the indexes "Peak hours" and "Off-peak hours" are emitted.
        How to do in Node-Red to separately retrieve a first index for peak hours and a second index for off-peak hours?
        Zuletzt geändert von Stives; 22.03.2023, 11:54.
          Hi
          Maybe look at the tariff? I have never used such datapoint, so i cannot help you on that.
            yes, there are 11 tariffs in total (0 to 10) with an index for each tariff.
            I don't know which node to use to, depending on the tariff, retrieve the value of the corresponding index​
              Hi
              you need a “switch” node and you need to switch based on the property msg.payload.tariff
                I used the switch node before with a "single" payload which included one action for the true load and another for the false load but here the payload is multiple with index, tariff, tariff validity and validity Energy.
                How to test one of the payload elements such as the price for example ?
                  you are going off topic with that question, that is not an KNX-node issue that's a question how to use Node-Red base nodes. Please open an extra thread or take a look in node red help sites.
                  With an inject node you can test allmost everything and on KNX-side you can use ETS group monitor to send the needed telegram on the bus.
                    ich bin relativ neu in NodeRed und beim "KNX Ultimate" Node hakt es gerade ein bisschen. Ich bekomme keine Verbindung mit dem MDT IP Interface (SCN-IP000.02). Soweit ich das hier gelesen habe, gibt es immer wieder Probleme mit der "IP Secure" funktion, diese gibt es aber bei dem 02 er Interface aber nicht. Was kann ich noch falsch machen?
                    Ich nutze NodeRed im IOBroker. Den KNX adapter im IOBroker habe ich deaktiviert. Aktuell liest die Heizungssteuerung (UVR 16x2) noch KNX Werte aus, liegt es evtl. daran?
                      Dein Interface kann kein TCP. Du müsstest "Tunnel UDP" benutzen.
                        JAAAA Danke meti! Es geht! Ich habe zwar "Tunnel UDP"​ auch schon getestet, habe aber nicht den kompletten NodeRed Adapter neu gestartet (nur deployed). Nach den adapter neustart funktioniert es jetzt.
                          ich bin auch neu in Node-Red und habe ein Problem mit der Node node-red-contrib-multipart-stream-decoder. Obwohl ich diese installiert habe, kommt die Fehlermeldung „Flows gestoppt wegen fehlender Node-Typen“.
                          Hat jemand eine Idee woran dies liegen kann oder ob weitere Nodes erforderlich sind?
                          Vielen Dank im Voraus und Gruß.
                            Was hat das mit dem KNX node zu tun?
                              Konnte keinen neuen Chat eröffnen. Evtl hat trotzdem einer eine Idee.
                              Vielen Dank euch.
                                Woran hapert es denn?
                                Gruß Bernhard
