KNX node for node-red
    Hi
    hmmmm…. You probably have some issues with the udp tunneling. Knx-Ultimate adhere to the KNX standards most as possible, so if it has problems in sending of any telegram, it tries 3 time to send it, as per knx standards, then it drops the connection.
    Not all knx nodes in nodered palettes does the same.
    Glad to hear that it’s working in multicast routing, but you still may have some networking issues, to be found and fix. ;-)
      TheMax74
      Can i call a HUE scence with your node? Any plans to implement it ?
      Gruß Stephan
        Hi epogo.
        Currently not and yes, it's planned. Do you need something else apart the scene?
          Hi Giovane,
          I have a problem with the hue light.
          It‘s possible to turn off and to dim.
          But not to switch on.
          I took a screenshot of the error messagey
          There are not too many options to make a mistake in the configuration….
          Olli​
          Zuletzt geändert von TheOlli; 14.07.2023, 06:29.
            Hi Olli
            The two links aren't working. What version of KNX-Ultimate are you using?
              Im using the latest Version 2.1.32 with the battery sensor.
              The link was just for the picture in the post.
              My workaround at the moment:
              knx-motion-sensor GA --> knx-ultimate-node
              If true, then send 100% dimming value to knx-ultimate-node --> knx GA light-dimming
              If false, write to knx-ultimate-node --> knx GA light on/off
              knx GA light-dimming --> knx-ultimate-hue-light dimming
              Thanks by the way for the tap-dial-node. Now I have a new controller for my sonos...
              Zuletzt geändert von TheOlli; 14.07.2023, 06:43.
                Hi Olli
                Ok, got it. Your light doesn't support GAMUT and this hasn't been correctly handled. I'll work on that... please stay tuned.
                  I have a group of four lights which should be controlled by one GA on/off and one GA for dimming.
                  Is it possible to add a hue-group-node?
                    Please update to v. 2.1.33 and let me know if it works without your workaround.
                      Hi Olli
                      I'll take a look at it.
                        I'll update to the latest version when I'm at home today. When did you upload the version .33?
                        My last update was yesterday, maybe I'm already using .33
                        The lights are two ikea tradfri and one HUE edison
                        https://www.ikea.com/it/it/p/tradfri...anco-90486785/
                        https://www.philips-hue.com/it-it/p/.../8719514342989
                        Zuletzt geändert von TheOlli; 14.07.2023, 07:01.
                          Hi Olli.
                          No no. You are on .32, because i've uploaded the .33 5 minutes ago, to fix your issue.
                            TheMax74
                            Looks good now!
                            I‘ll test the night lighting funtiction tonight.
                              Hi
                              the group light control is now inside the hue light node.
                              V. 2.1.34 is out, with this addition, plus a massive fixes and huge rewrite of the hue engine.
                              I'll add the "blink color" functionality in the next days, as soon as i've some spare time!
                                Hi Max,
                                first I want say a big THANK YOU for providing knx-ultimate to the community!
                                Short intro:
                                In 2018 I decided to install KNX in my house. I use it for controlling lights,
                                heating, shuttes, opening garage and house doors, monitoring fire alarms and
                                some surveillance stuff and of course some bells and whistles as most of the members here.
                                I did all by myself. Its working fine and stable - of course by solving some issues
                                with the help of this great forum :-)
                                Then I wanted to have the controls on a mobile device too.
                                I installed CometVisu on a Rasperry Pi and made it running
                                (in most cases) too.
                                But still there are some open wishes:
                                - color picker (now available in cometVisu)
                                - link to HUE lamps
                                - alert messaging by SMS, push notification,...
                                - audio output
                                - logging data
                                I evaluated different alternatives to realize this -
                                adding some sw packages to raspian/CometVisu or to change to OpenHab -
                                but with all it would have become a lot of work and
                                unpredictable success for me as a linux amateur.
                                By the way - maybe I am to stupid (I am an el. engineer with some
                                programming skills) - I played around with Openhab a few days
                                but I didn't really get what I am doing there with things, items, channels, ... LOL
                                Regarding knx-ultimate:
                                Recently I found some info about Node-red and knx ultimate here.
                                Looking into details, a recognized THAT is what i need!
                                So I am playing around with Node-red and porting one by one functionality to it.
                                Wow - how easy! For all my above wishes there seems to be a solution
                                available!
                                Regarding embedding HUE lamps I would like to share some findings.
                                Some behavior resp. setup works not as expected - may I share here?
                                BR Ruediger​
