Reading a GA and displaying the value in decimal via PHP
    Hi Ray/Marc?,
    I have found your post on the French google group. I think the F2_decode function is the right one. But you could compare it to Nils function.
    Hth
    Marcus
      Hi Nils,
      Nice to hear from you again.
      Zitat von NilsS Beitrag anzeigen
      Its in python but that shouldn't be to hard to port to php.
      Mmmm, this is far beyhond my modest programming skills
      I'm still puzzled by the post on the professional forum, it clearly says "
      Umrechnung Temperaturen" and I've no reason to suspect it.
      Then, it could be that GroupRead doesn't supply the data in a format compatible with the conversion routine.
      Thank you for your kind help
        Zitat von Warichet Beitrag anzeigen
        0.23 which is totally inconsistent
        as I think about it. It couldn't be a raw value. There are only bits (represented as integers or hex) on the wire. The conversion to float happens afterwards.
        In your case you get a float from the groupread command. That doesn't seem right.
        sorry, i couldn't help you further.
        Marcus
