Reading a GA and displaying the value in decimal via PHP
I'm trying to read and display a GA (temperature) with PHP.
I've read the procedure on the KNX site, but I wonder if someone has already done it with PHP or similar ? (from ETS -> décimal)
I'm not sure that I could help you, but I give it a try. What is the return value of the Groupwrite command?
And you do have an running eibd, which listens on 127.0.0.1.
Yes, I understand that's the standard way of doing.
eibd is running on a NAS QNAP with PHP5.
I've another application to display KNX data on a Cisco phone, also using PHP, and it is working fine, using the same GroupRead.
I think I see your Problem. You are using the wrong decoding function. Floating Point values are a little ugly to decode, but there should be a function in the client.
I'm on a Road Trip and have no access to my dev computer. => you have to Look for the right function by yourself.
