Reading a GA and displaying the value in decimal via PHP
    I'm trying to read and display a GA (temperature) with PHP.
    I've read the procedure on the KNX site, but I wonder if someone has already done it with PHP or similar ? (from ETS -> décimal)
    Thank you.
    Maybe this, testing ...
      Hoi
      Have a look at PDF:
      http://www.knx.org/fileadmin/downloa....5.00%20AS.zip
      Page 31 I think
      3.10 Datapoint Types “2-Octet Float Value”
      Format: 2 octets: F16
      octet nr: 2 MSB 1 LSB
      field names: FloatValue
      encoding: MEEEEMMM MMMMMMMMM
      Encoding:
      FloatValue = (0,01*M)*2(E)
      E = [0 … 15]
      M = [-2 048 … 2 047], two’s complement notation
      For all Datapoint Types 9.xxx, the encoded value 7FFFh shall always be used to denote invalid
      data.
      Range: [-671 088,64 … 670 760,96]
      PDT: PDT_KNX_FLOAT
      Grüsse Bodo
        see the eibd examples threre is a simple php client.
        hth
        Marcus
          I don't feel at home within eibd, I would appreciate a pointer to the file
          Thank you
            I dont know the path. Download the source code and look for a php file. On Linux you could use: find . | grep php
            So Long
            Marcus
              That's what I did before posting.
              No luck
              Thanks anyway
                I'm unable to make anything consistent with the conversion.
                Here is an extract of the code
                PHP-Code:
                $value GroupRead("127.0.0.1","0/6/38");
                $eis5 hexdec($value);
                $wert = ($eis5 0x07ff);
                if ((
                $eis5 0x08000) != 0)
                $wert $wert 0xfffff800;
                $wert $wert *-1;
                $wert $wert << (($eis5 0x07800) >> 11);
                if ((
                $wert $wert * -1;
                $val $wert/100;
                $string "Temp: " $val "°C"
                Maybe a sharp eye will see the problem ?
                  There is something wrong with the GroupRead
                  When I force the input to a known value, the conversion works fine, i.e: 1902 = 20,64°
                  PHP-Code:
                  $value 1902;
                  if ((
                  $wert $wert *-1;
                  if ((
                  $wert $wert * -1;
                  $val $wert/100;
                    This is beyhond my understanding.
                    The command GroupRead is not to be suspected as it works in other applications in the same environment.
                    The conversion is not to be suspected as it works with a fixed value.
                    But the 2 together, no go.
                    Anyone has an idea, please ?
                      I'm not sure that I could help you, but I give it a try. What is the return value of the Groupwrite command?
                      And you do have an running eibd, which listens on 127.0.0.1.
                      Marcus
                        I give it a try.
                        Much appreciated, thank you aforehand
                        0.23 which is totally inconsistent
                        The actual temp as shown in the Visu is 21.8
                        Yes, I understand that's the standard way of doing.
                        eibd is running on a NAS QNAP with PHP5.
                        I've another application to display KNX data on a Cisco phone, also using PHP, and it is working fine, using the same GroupRead.
                        Thanks
                          I think I see your Problem. You are using the wrong decoding function. Floating Point values are a little ugly to decode, but there should be a function in the client.
                          I'm on a Road Trip and have no access to my dev computer. => you have to Look for the right function by yourself.
                          So long
                          Marcus
                            Ah ?!? some light in my tunnel
                            I've seen the function f2_decode($val), it doesn't work either, maybe it was the wrong one.
                            OK, I'll have a closer look.
                            Thank you for the hint.
                            PS: I was convinced it was the right function, because when I type a value, as seen in ETS, I get the right output.
                              Hi Ray,
                              maybe this can help you get eis5 (DPT9) decoding done.
                              SourceForge.net Repository - [openautomation] Contents of /PyWireGate/trunk/knx_connector/DPT_Types.py
                              Its in python but that shouldn't be to hard to port to php.
                              There is also a DPT Type guessing function.
                              Nils
                              aktuelle Bausteine:
