Zitat von ChrisChros
------------------------------------------------- Measure | 1 min. | 5 min | 15 min | since start ------------------------------------------------- RX Bit/s | 0049 | 0093 | 0092 | 0085 TX Bit/s | 0006 | 0003 | 0002 | 0009 RT Bit/s | 0056 | 0096 | 0095 | 0094 ------------------------------------------------- RX T/s | 00.44 | 00.84 | 00.83 | 00.72 TX T/s | 00.06 | 00.04 | 00.04 | 00.07 RT T/s | 00.50 | 00.89 | 00.87 | 00.80 ------------------------------------------------- RX % | 00.88 | 01.69 | 01.66 | 01.45 TX % | 00.12 | 00.09 | 00.08 | 00.15 RT % | 01.00 | 01.78 | 01.74 | 01.61 ------------------------------------------------- MaxR T/s | 02 | 25 | 25 | 37 MaxT T/s | 00 | 03 | 03 | 18 MxRT T/s | 02 | 25 | 25 | 43 ------------------------------------------------- Maximum load at 23:05:02 12.03.2021 (UTC)
# stats Uptime: 8 day(s), 18:19 KNX communication statistics: TX to IP (all)..: 5514985 (ca. 437 t/m) TX to KNX.......: 11176 (ca. 0 t/m) RX from KNX.....: 10939586 (ca. 866 t/m) Overflow to IP..: 223 Overflow to KNX.: 0 TX tunnel re-req: 1256 TP bus voltage..: 29.91 V TP bus current..: 16.2 mA TP Temperature..: 21.4 C TX TP rate......: 50 T/s (= 100 %)
# busload ------------------------------------------------- Measure | 1 min. | 5 min | 15 min | since start ------------------------------------------------- RX Bit/s | 0802 | 0670 | 0673 | 0668 TX Bit/s | 0000 | 0000 | 0000 | 0003 RT Bit/s | 0802 | 0670 | 0673 | 0672 ------------------------------------------------- RX T/s | 08.65 | 07.24 | 07.26 | 07.22 TX T/s | 00.00 | 00.00 | 00.00 | 00.01 RT T/s | 08.65 | 07.24 | 07.26 | 07.24 ------------------------------------------------- RX % | 17.31 | 14.48 | 14.53 | 14.45 TX % | 00.00 | 00.00 | 00.00 | 00.02 RT % | 17.31 | 14.48 | 14.53 | 14.48 ------------------------------------------------- MaxR T/s | 12 | 26 | 30 | 37 MaxT T/s | 00 | 00 | 00 | 20 MxRT T/s | 12 | 26 | 30 | 49 ------------------------------------------------- Maximum load at 16:44:59 16.03.2021 (UTC)
