heute wollte ich PL30 einspielen. Unter "Liste der zu aktualisierenden Pakete" bekomme ich folgendes:
Nach einem Klick auf "Alle verfügbaren Updates installieren" bekomme ich:
Was ist hier das Problem? Wie kann ich es lösen? Per Kommandozeile?
Wartungs-VPN ist aktiviert: wiregate302.
Danke
Micha
Reading package lists... Building dependency tree... Reading state information... The following packages will be upgraded: eibd-config-wg libow-perl libowfs27 libownet-perl linknx owfs-fuse owfs-httpd owfs-server webmin-wiregate wg-patch wiregated 11 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Inst webmin-wiregate [0.3-41] (0.3-43 stable) Inst eibd-config-wg [0.2-11] (0.2-12 stable) Inst libowfs27 [2.8p2] (2.8p14-2+nmu1 stable) Inst owfs-server [2.8p2] (2.8p14-2+nmu1 stable) Inst wiregated [0.9-41] (0.9-45 stable) Inst wg-patch [0.0.29-1] (0.0.30-2 stable) Inst libow-perl [2.8p2] (2.8p14-2+nmu1 stable) Inst libownet-perl [2.8p2] (2.8p14-2+nmu1 stable) Inst linknx [0.0.1.28-1] (0.0.1.30-1 stable) Inst owfs-fuse [2.8p2] (2.8p14-2+nmu1 stable) Inst owfs-httpd [2.8p2] (2.8p14-2+nmu1 stable) Conf webmin-wiregate (0.3-43 stable) Conf eibd-config-wg (0.2-12 stable) Conf libowfs27 (2.8p14-2+nmu1 stable) Conf owfs-server (2.8p14-2+nmu1 stable) Conf wg-patch (0.0.30-2 stable) Conf wiregated (0.9-45 stable) Conf libow-perl (2.8p14-2+nmu1 stable) Conf libownet-perl (2.8p14-2+nmu1 stable) Conf linknx (0.0.1.30-1 stable) Conf owfs-fuse (2.8p14-2+nmu1 stable) Conf owfs-httpd (2.8p14-2+nmu1 stable)
Reading package lists... Building dependency tree... Reading state information... The following packages will be upgraded: eibd-config-wg libow-perl libowfs27 libownet-perl linknx owfs-fuse owfs-httpd owfs-server webmin-wiregate wg-patch wiregated 11 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 5157kB of archives. After this operation, 11.5MB of additional disk space will be used. WARNING: The following packages cannot be authenticated! webmin-wiregate eibd-config-wg libowfs27 owfs-server wiregated wg-patch libow-perl libownet-perl linknx owfs-fuse owfs-httpd E: There are problems and -y was used without --force-yes
Danke
Micha
