Wie sieht denn Dein Plugin aus ?
P.S: Welche Modell hast Du gelötet? Hat der ne galvanische Trennung?
.use warnings;
use strict;
use EBus;
my $usb = '/dev/ttyUSB0'; #eBus Schnittstelle
### Vaillant Konfiguration ###
my @sets;
push @sets, { name => "RT_soll", GA => "0/0/0", QQ => "00", ZZ => "50", PB => "B5", SB => "05", NN => "02", DB1 => "01", DB2 => "" };
push @sets, { name => "RT_min", GA => "0/0/0", QQ => "00", ZZ => "50", PB => "B5", SB => "05", NN => "02", DB1 => "0A", DB2 => "" };
push @sets, { name => "HK_mode", GA => "0/5/102", QQ => "00", ZZ => "50", PB => "B5", SB => "05", NN => "02", DB1 => "02", DB2 => "" };
push @sets, { name => "HK_curve", GA => "0/0/0", QQ => "00", ZZ => "50", PB => "B5", SB => "05", NN => "03", DB1 => "0B", DB2 => "", DB3 => "00" };
push @sets, { name => "HK_party", GA => "0/0/0", QQ => "00", ZZ => "50", PB => "B5", SB => "05", NN => "02", DB1 => "05", DB2 => "" };
push @sets, { name => "HK_spar", GA => "0/0/0", QQ => "00", ZZ => "50", PB => "B5", SB => "05", NN => "02", DB1 => "07", DB2 => "" };
push @sets, { name => "AT_off", GA => "0/0/0", QQ => "00", ZZ => "50", PB => "B5", SB => "09", NN => "04", DB1 => "0E", DB2 => "36", DB3 => "00", DB4 => "", DB5 => "00" };
push @sets, { name => "WW_load", GA => "0/5/101", QQ => "10", ZZ => "FE", PB => "B5", SB => "05", NN => "02", DB1 => "06", DB2 => "" };
push @sets, { name => "WW_soll", GA => "0/0/0", QQ => "00", ZZ => "25", PB => "B5", SB => "09", NN => "05", DB1 => "0E", DB2 => "82", DB3 => "00", DB4 => "", DB5 => "" };
push @sets, { name => "WW_min", GA => "0/0/0", QQ => "00", ZZ => "25", PB => "B5", SB => "09", NN => "05", DB1 => "0E", DB2 => "82", DB3 => "00", DB4 => "", DB5 => "" };
push @sets, { name => "WW_mode", GA => "0/0/0", QQ => "00", ZZ => "25", PB => "B5", SB => "09", NN => "04", DB1 => "0E", DB2 => "2B", DB3 => "00", DB4 => ""};
push @sets, { name => "HOL_date", GA => "0/0/0", QQ => "00", ZZ => "FE", PB => "B5", SB => "0B", NN => "08", DB1 => "01", DB2 => "Nr", DB3 => "ST", DB4 => "SM", DB5 => "SJ", DB6 => "ET", DB7 => "EM", DB8 => "EJ"};###FIXME DATATYP
push @sets, { name => "HOL_temp", GA => "0/0/0", QQ => "00", ZZ => "FE", PB => "B5", SB => "05", NN => "02", DB1 => "2A", DB2 => ""};
push @sets, { name => "HK_int", GA => "0/5/0", QQ => "10", ZZ => "08", PB => "B5", SB => "05", NN => "05", DB1 => "0E", DB2 => "7C", DB3 => "00", DB4 => "", DB5 => "FF" };
### Ende Vaillant Konfiguration ###
### M A I N ###
my $do = $ARGV[0];
my $value = $ARGV[1];
chomp $do;
chomp $value;
print ("Befehl = $do","\n");
print ("Wert = $value","\n");
foreach my $set (@sets) {
if ($do eq $set->{name} )
my $val = $value;
my $subname = $set->{name}; # $subname bekommt den Namen der entsprecheden sub
my $subref = \&$subname; # jetzt wird $subref die entsprechende sub zugewiesen
my $command = addCRC(&$subref($val));
print ("Command = $command","\n");
&send ($command);
### V A I L L A N T S U B S ###
#lassen sich bestimmt noch optimieren in dem man die Konfiguration etwas erweitert
### Sparen bis ... 30min = 0,5 Stunden (21:30Uhr = 21,5) ###
sub HK_spar
foreach my $set(@sets){
if ($set->{name} eq "HK_spar")
my $input = $_[0];
my $val = (sprintf "%02d",$input);
$val = encode_d1c ($val);
my $message = $set->{QQ}.$set->{ZZ}.$set->{PB}.$set->{SB}.$set->{NN}.$set->{DB1}.$val;
return $message;
### Ferientemperatur ###
sub HOL_temp
if ($set->{name} eq "HOL_temp")
my $input = $_[0];
$val = encode_d1b ($val);
return $message;
### Raumtemperatur Soll ###
sub RT_soll
if ($set->{name} eq "RT_soll")
my $input = $_[0];
return $message;
### Raumtemperatur Absenkung ###
sub RT_min
if ($set->{name} eq "RT_min")
my $input = $_[0];
return $message;
### 1-Heizen, 2-Aus, 3-Auto, 4-Eco, 5-Absenken ###
sub HK_mode
if ($set->{name} eq "HK_mode")
my $input = $_[0];
my $val = (sprintf "%02d",int($input));
return $message;
### Heizkurve 0,20 etc ###
sub HK_curve
if ($set->{name} eq "HK_curve")
my $input = $_[0];
$input *= 100;
$val = encode_d1b($val);
my $message = $set->{QQ}.$set->{ZZ}.$set->{PB}.$set->{SB}.$set->{NN}.$set->{DB1}.$val.$set->{DB3};
return $message;
### 0-Partymodus aus, 1-Partymodus an ###
sub HK_party
if ($set->{name} eq "HK_party")
my $input = $_[0];
return $message;
### Betriebsmodus WW 1-aus, 2-an, 3-auto ###
sub WW_mode
if ($set->{name} eq "WW_mode")
my $input = $_[0];
my $message = $set->{QQ}.$set->{ZZ}.$set->{PB}.$set->{SB}.$set->{NN}.$set->{DB1}.$set->{DB2}.$set->{DB3}.$val;
return $message;
### 0-Speicherladung abbrechen, 1-Speicherladung ###
sub WW_load
if ($set->{name} eq "WW_load")
my $input = $_[0];
return $message;
### Energieintegral setzen ###
sub HK_int
if ($set->{name} eq "HK_int")
my $input = $_[0];
my $message = $set->{QQ}.$set->{ZZ}.$set->{PB}.$set->{SB}.$set->{NN}.$set->{DB1}.$set->{DB2}.$set->{DB3}.$val.$set->{DB3};
return $message;
### Außentemperatur Abschaltgrenze ###
sub AT_off
if ($set->{name} eq "AT_off")
my $input = $_[0];
return $message;
### Solltemperatur WW-Speicher ###
sub WW_soll
if ($set->{name} eq "WW_soll")
my $input = $_[0];
$val = encode_d2c($val);
return $message;
### Min.-Temperatur WW-Speicher ###
sub WW_min
if ($set->{name} eq "WW_min")
my $input = $_[0];
return $message;
### D A T E N K O N V E R T I E R U N G ####
### FIX ME !!!!!
### BCD ###
sub decode_bcd {
#return (unpack "H*", pack "C*",hex($_[0]));
unpack "H*", $_[0]; ####?????
sub encode_bcd {
return pack 'H*', join '', $_[0];
### DATA1b ###
sub decode_d1b{ #1byte signed
my $val = hex(shift);
return $val > 127 ? $val-256 : $val;
sub encode_d1b { #### F I X M E !!!!!
my $y = shift;
$y *= 256;
$y = $y & 0xffff if ($y < 0);
my $hb = int $y/256;
return (sprintf("%0.2X", $hb));
### DATA1c
sub decode_d1c {
my $y = hex ($_[0])/2;
return $y;
sub encode_d1c {
return sprintf "%x",(($_[0])*2);
### DATA2b ###
sub decode_d2b {
return unpack("s", pack("s", hex($_[0].$_[1]))) / 256;
sub encode_d2b {
my ($hb, $lb) = unpack("H[2]H[2]", pack("s", $_[0] * 256));
return $lb.$hb;
### alternativ
#sub decodex_d2b{
# my $hb = hex($_[0]);
# my $lb = hex($_[1]);
# if ($hb & 0x80) {
# return -( (~$hb & 255) + ((~$lb & 255) + 1)/256 );
# else {
# return $hb + $lb/256;
#sub encodex_d2b {
# my $y = shift;
# $y *= 256;
# $y = $y & 0xffff if ($y < 0);
# my $hb = int $y/256;
# my $lb = $y % 256;
# return (sprintf("%0.2X", $hb), sprintf("%0.2X", $lb));
### DATA2c ###
sub decode_d2c{
my $high = $_[1];
my $low = $_[0];
return unpack("s",(pack("H4", $low.$high)))/16;
sub encode_d2c{
my $val = $_[0];
my $temp_hex = unpack("H4", pack("n", ($val)*16));
# change lowbyte/highbyte -> lowbyte first
return substr($temp_hex,2,4).substr($temp_hex,0,2);
### A D D C R C ###
### CRC hinzufuegen
sub addCRC
my $string = $_[0];
my $temp_string = pack("H*","$string"); ### geht auch!
my $crc = new EBus();
my $check = $crc->calcCrcExpanded($temp_string);
my $crcfinal = uc(sprintf("%02x", $check));
my $finalStr = $string.$crcfinal;
### S E N D E N ###
sub send
my $raw = shift;
$raw =~ s/([0-9a-f]{2})/chr( hex( $1 ) )/gie;
open(my $fh,'|-',"socat -t1 - $usb,b2400") or return 0;
binmode( $fh );
print $fh $raw;
close( $fh ) or return 0;
return 1;
#print ("echo $command | perl -ne 's/([0-9a-f]{2})/print chr hex $1/gie' | socat -t1 - $usb,b2400 | od -tx1");
Bin zwar Dein Script erst mal nur kurz durchgegangen, aber das hört sich alles sehr gut an, auch wenn ich selbst erst noch am Decodieren auf meiner Windoof Kiste festhänge.... Aber einen ersten Ansporn hast Du mir dennoch schon gegeben und ich habe mir eben mal den EBUS in mein Büro gelegt...
2012-10-05 20:33:50.451,eBus1.pl,Received: 1023,0s, 2012-10-05 20:33:50.978,eBus1.pl,Received: B5040131,0s, 2012-10-05 20:33:51.503,eBus1.pl,Received: F6,0s, 2012-10-05 20:33:52.030,eBus1.pl,Received: 00AA,0s,
# Beta fuer eBus-Anbindung von Heizungen/Waermepumpen
# Diese Beta bezieht sich auf eine Vaillant VWS 82-3 Waermepumpe
# Fuer jeden Befehl wurde vorher eine sub erstellt die die Daten an die richtige Stelle setzt und
# richtig codiert. Dies laesst sich bestimmt noch schlanker gestalten in dem man die Konfigurationszeilen erweitert.
# Der generelle Aufbau eines eBus-Telegramms: QQ ZZ PB SB NN DB1...DBx CRC
# QQ = Quelladresse, ZZ = Zieladresse, PB = Primaerbefehl, SB = Sekundarbefehl, NN = Anzahl der Datenbytes, DB1...DBx = Datenbytes, CRC = Checksummenbyte.
# Teils liegen die Daten die es zu senden gibt an unterschiedlichen Stellen, in der Konfiguration sind diese dann leer (z.B. DB2="").
# Wiregte-Socket-Einstellungen:
# Socket 1: "-" und "Socket: /dev/ttyUSB0" (hier eigenen Adapter) und "Optionen: raw,b2400,echo=0"
# Socket 1: "udp-datagram" und "Socket: localhost:50110 und "Optionen: bind=localhost:50111,reuseaddr"
# aktiviert und bidirektional
# Das Perl-Modul EBus.pm muss installiert sein, vergleiche hierzu:
# https://knx-user-forum.de/253728-post64.html
# 06.10.2012
# JuMi2006 (https://knx-user-forum.de)
# Version 0.1
use warnings;
use strict;
use EBus;
my $socknum = 303; # Eindeutige Nummer des Sockets +1
my $send_ip = "localhost"; # Sendeport (UDP, siehe in Socket-Einstellungen)
my $send_port = "50111"; # Sendeport (UDP, siehe in Socket-Einstellungen)
my $recv_ip = "localhost"; # Empfangsport (UDP, siehe in Socket-Einstellungen)
my $recv_port = "50110"; # Empfangsport (UDP, siehe in Socket-Einstellungen)
my @sets;
push @sets, { name => "HK_int", GA => "0/0/0", QQ => "10", ZZ => "08", PB => "B5", SB => "05", NN => "05", DB1 => "0E", DB2 => "7C", DB3 => "00", DB4 => "", DB5 => "FF" };
### M A I N ###
### Socket einrichten ###
$plugin_info{$plugname.'_cycle'} = 300;
if (!$socket[$socknum]) { # socket erstellen
$socket[$socknum] = IO::Socket::INET->new(LocalPort => $recv_port,
Proto => "udp",
LocalAddr => $recv_ip,
PeerPort => $send_port,
PeerAddr => $send_ip,
ReuseAddr => 1
or return ("open of $recv_ip : $recv_port failed: $!");
$socksel->add($socket[$socknum]); # add socket to select
$plugin_socket_subscribe{$socket[$socknum]} = $plugname; # subscribe plugin
plugin_log($plugname,'Soket verbunden. Soketnummer: ' . $socknum);
return "opened Socket $socknum";
### Konfiguration einlesen ###
$plugin_subscribe{$set->{GA}}{$plugname} = 1; # An Gruppenadresse anmelden
if ($msg{'dst'} eq $set->{GA}) # Auf eintreffendes KNX-Telegramm reagiern + anhand der GA filtern
plugin_log($plugname, "Befehlsgruppe: $set->{name}"); # Logging der Befehlsgruppe
my $val = $msg{'value'}; # Wert aus Telegramm filtern
my $command = addCRC(&$subref($val)); # Befehls-Sub ausf�hren und CRC anh�ngen
&send ($command); # Befehl senden
### S E N D E N ###
sub send
my $cmd = shift;
my $raw = $cmd;
$raw =~ s/([0-9a-f]{2})/chr( hex( $1 ) )/gie; # !!! Umwandlung des Hex-Strings
plugin_log($plugname, "send: $cmd");
syswrite($socket[$socknum], $raw);
sub HK_spar
my $input = $_[0];
return $message;
sub HOL_temp
my $input = $_[0];
return $message;
sub RT_soll
my $input = $_[0];
return $message;
sub RT_min
my $input = $_[0];
return $message;
sub HK_mode
my $input = $_[0];
return $message;
sub HK_curve
my $input = $_[0];
$input *= 100;
return $message;
sub HK_party
my $input = $_[0];
return $message;
sub WW_mode
my $input = $_[0];
return $message;
sub WW_load
my $input = $_[0];
return $message;
sub HK_int
my $input = $_[0];
return $message;
### Au�entemperatur Abschaltgrenze ###
sub AT_off
my $input = $_[0];
return $message;
sub WW_soll
my $input = $_[0];
return $message;
sub WW_min
my $input = $_[0];
return $message;
### BCD ### ### FIX ME !!!!!
sub decode_bcd {
sub encode_bcd {
### DATA1b ###
my $y = shift;
$y *= 256;
### DATA1c
sub decode_d1c {
return $y;
sub encode_d1c {
### DATA2b ###
sub decode_d2b {
sub encode_d2b {
return $lb.$hb;
### alternativ
#sub decodex_d2b{
# if ($hb & 0x80) {
# else {
#sub encodex_d2b {
# my $y = shift;
# $y *= 256;
### DATA2c ###
sub decode_d2c{
my $high = $_[1];
my $low = $_[0];
sub encode_d2c{
my $val = $_[0];
### A D D C R C ###
### CRC hinzufuegen
sub addCRC
my $string = $_[0];
### V O M E - B U S L E S E N ###
#if ($fh) { # Wenn eBus ein Telegramm sendet, wird ab hier der entsprechende Status ausgelesen.
# my $buf;
# recv($fh,$buf,255,0);
# my $bufhex = $buf;
# $bufhex =~ s/(.)/sprintf("%.2X",ord($1))/eg;
# return "Received: $bufhex";
return;
